Author Topic: Cb750 f2 k4 engine bolts and ideas  (Read 4587 times)
Offline onethumb
« on: June 24, 2016, 01:57:17 PM »
Hi all, I've been and done that thing when you're doing a complete strip down and rebuild then you get stuck on a part walk away to think about and don't go back till someone asks"how's the build going?"
Well I'm back still got the same problem but now I'm going to ask you all for some help.
I want to ditch the massive rear set brackets in place of an aftermarket one but by doing this the long engine bolts that go through the frame are way too long and as there're shouldered bolts I was wondering if the bolts from a k4 or other would fit and solve this first problem.
Also due to costs and time I was thinking of giving it a rat look! Thoughts and ideas gladly accepted.
Thanks all.
Offline Orcade-Ian
    • Older Vehicle Web
Re: Cb750 f2 k4 engine bolts and ideas
« Reply #1 on: June 24, 2016, 07:52:09 PM »
Hi,
How about asking a friendly chap (or chapess) with a lathe and the expertise to shorten and re-thread the originals? Not familiar with the 750's but presumably you need to shorten them by 2 thicknesses of bracket.
Have you got a 'Men's Shed' in your area? They might have the necessary skills and equipment ( Google 'men's shed') I only know about this rapidly expanding network because I'm involved with setting one up in Orkney.
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Offline onethumb
« Reply #2 on: June 24, 2016, 08:30:45 PM »
Cheers I'll have a look.
Offline yozzer74
« Reply #3 on: June 24, 2016, 08:48:31 PM »
I had mine chopped and threads put back on .
Offline onethumb
« Reply #4 on: June 24, 2016, 08:54:16 PM »
Hi yozzer, that might be the way I have to go. I know the k4 bolts aren't as long so thought I might be able to go that way.
« Reply #5 on: June 24, 2016, 10:08:03 PM »
The K7 is paired with the F2 so may offer best options if any differences are there.
CR750 maybe able to shed some more light on that route.
Offline onethumb
« Reply #6 on: June 24, 2016, 10:23:01 PM »
Thats the information I was looking for.
That's well worth knowing. I'll start the search. Thanks.
Offline MarkCR750
« Reply #7 on: June 24, 2016, 11:01:12 PM »
I bought a stainless bolt set on ebay, the only one that was too long was the one that goes through the foot pegs (because there are no foot pegs in that position now), I used a spacer to take up the slack on that one but will get it cut down and thread recut at some point, I can only see this one for the 550 at the moment but you could email them to ask.
http://www.ebay.co.uk/itm/MOTORCYCLE-STAINLESS-STEEL-HONDA-CB550-FOUR-SOHC-ENGINE-MOUNTS-BOLT-KIT-/361582221866?hash=item542ffada2a:g:288AAOSwiYFXD1si
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Offline onethumb
« Reply #8 on: June 24, 2016, 11:08:43 PM »
Hi markCR750, thank you. I've sent an email so hopefully I'll get a bit more info.
Thanks again.
Steve.
Offline yozzer74
« Reply #9 on: June 24, 2016, 11:40:15 PM »
This is mine after .I had both ends cut off and threaded then two titanium flanges nuts on each end .and 2 stainless steel caps turned up on ends . [ Guests cannot view attachments ]
Offline MarkCR750
« Reply #10 on: June 25, 2016, 06:36:30 AM »
This is mine after .I had both ends cut off and threaded then two titanium flanges nuts on each end .and 2 stainless steel caps turned up on ends . (Attachment Link)
Neat looking job there Yozzer, very nice.
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
« Reply #11 on: June 25, 2016, 09:01:06 AM »
That looks really nicely engineered yozzer,  those special parts make the finished bike look so good.
Offline onethumb
« Reply #12 on: June 25, 2016, 10:51:06 AM »
That is top level. Going for a brat scrambler look so that finish would be wasted on me and mine.
Offline onethumb
« Reply #13 on: June 25, 2016, 10:55:20 AM »
Yozzer just being cheeky but you wouldn't happen to have the templates for those beauties or the dimensions. I spoke to one off welding and he said that he hasn't got them?
Offline yozzer74
« Reply #14 on: June 25, 2016, 12:42:35 PM »
Do you mean the temples for the hangers .if so I do have them .
