CB750
Intro
3
4
5
6
7
Topic: Intro (Read 47686 times)
jimshea
Re:Intro
Reply #45 on:
February 19, 2007, 10:03:50 AM »
Looks great; is that bike half scale or are you a big bloke?
Voxonda
SOHC Member
Re:Intro
Reply #46 on:
February 21, 2007, 05:34:51 PM »
Listen to the music:
http://www.youtube.com/watch?v=zXXuEvavRFM
See ya, Rob
Post edited by: Voxonda, at: 2007/02/21 18:37
Better sorry for failing than for the lack of trying.
Voxonda
SOHC Member
Re:Intro
Reply #47 on:
February 23, 2007, 10:55:10 PM »
This week I dismantled the 'replica' bike to have the frame sandblasted and painted, so I can start with building up the bike. Changed to another set of clipons because had to move the brake and clutch lever more to the inside because of the 'endurance' fairing. Will show some pictures of the proces.
See ya, Rob
Voxonda
SOHC Member
Re:Intro
Reply #48 on:
February 28, 2007, 09:13:20 PM »
Hey overthere,
It's a bit slow because I'm waiting for the blasted and painted frame so I can begin to build the bike. But for my other bike, the 'Hailwood' I bought a K&J box swingarm, build in Germany. Although it was originally for a Kwacker, I will make it fit and redo the chainadjusters.
Just had no time to build anotherone myself.
Post edited by: Voxonda, at: 2007/02/28 21:14
Post edited by: Voxonda, at: 2007/02/28 21:15
Voxonda
SOHC Member
Re:Intro
Reply #49 on:
March 08, 2007, 10:51:55 PM »
Hey people,
It's been awhile but that doesn't mean I am not doing anything. While waiting for my frame to come back from the painter, I'm working on the other one. Changed the position of the rev counter, because it interferred with the brake- and gas cables. Just made a bracket from stainless and some alloy mounting studs.
Post edited by: Voxonda, at: 2007/03/08 22:54
Voxonda
SOHC Member
Re:Intro
Reply #50 on:
March 08, 2007, 10:57:12 PM »
Forgot the pic, sorry;
Voxonda
SOHC Member
Re:Intro
Reply #51 on:
March 08, 2007, 10:59:04 PM »
And mounted it:
On the pic it looks like it's position is to flat but I've got a good view of the counter.
Greetz, Rob
Voxonda
SOHC Member
Re:Intro
Reply #52 on:
March 21, 2007, 06:32:35 PM »
Still no sign of my freshly painted frame, so I keep on working on the other bike. Have to change the exhaust system because of the noise level of the 4 megga's. Keep running into trouble with the 'guys in blue'. Since there are not a lot of aftermarket systems available anymore, have to build one myself. Am building a Yoshimura look-a-like 4 into 1.
Like this one.
Post edited by: Voxonda, at: 2007/03/21 18:34
Voxonda
SOHC Member
Re:Intro
Reply #53 on:
March 21, 2007, 06:37:45 PM »
Using the original items because of the fine flowing curves it's starting to look like something.
Try to keep the oilfilter accessable
Post edited by: Voxonda, at: 2007/03/21 18:42
Voxonda
SOHC Member
Re:Intro
Reply #54 on:
March 21, 2007, 06:39:37 PM »
One from the side with a collector.
You can clearly see the curved lines.
Greetz. Rob
Post edited by: Voxonda, at: 2007/03/21 18:40
Voxonda
SOHC Member
Re:Intro
Reply #55 on:
March 24, 2007, 10:51:04 PM »
At last, after 3 weeks, I got my powdercoated frame back and have started the final assembly:
Voxonda
SOHC Member
Re:Intro
Reply #56 on:
March 24, 2007, 10:53:11 PM »
Have put on the frontstay and seatmountings and footrests:
Greetz, Rob
Voxonda
SOHC Member
Re:Intro
Reply #57 on:
April 09, 2007, 02:23:39 PM »
And now it's back on it's feet:
Best regards, Rob
Post edited by: Voxonda, at: 2007/04/09 14:25
Voxonda
SOHC Member
Re:Intro
Reply #58 on:
April 09, 2007, 02:26:37 PM »
And the other one is coming along also:
Post edited by: Voxonda, at: 2007/04/09 14:27
Voxonda
SOHC Member
Re:Intro
Reply #59 on:
May 23, 2007, 08:51:17 PM »
It's been some time ago, but I keep following this forum. Still busy with the replica's. Here's a update: Changed wheels, build a 4 into 1 'screamer', a bit loud, but that saves lives isn't it? Rebuild the front calipers, made some brake pistons on the lathe. Put on a new AVON Roadrider. There is more to come this week. Will keep you posted.
Cheers, Rob
Post edited by: Voxonda, at: 2007/05/23 20:53
Post edited by: Voxonda, at: 2007/05/24 06:58
3
4
5
6
7
CB750
Intro
