Author Topic: safely freeing a seized brake piston  (Read 5897 times)
jimv50
« on: June 25, 2016, 08:53:53 PM »
This man is my new workshop hero.
Offline UK Pete
Re: safely freeing a seized brake piston
« Reply #1 on: June 25, 2016, 09:09:03 PM »
Good tip thanks for sharing
pete
Offline onethumb
« Reply #2 on: July 17, 2016, 11:57:03 AM »
That is a good tip. Used the same idea on the swing arm bushes.
« Reply #3 on: July 17, 2016, 03:59:59 PM »
Is that an expanding rawl bolt in there. Like it.
Sent from my Nexus 6 using Tapatalk
Offline Green1
« Reply #4 on: July 17, 2016, 08:05:54 PM »
I prefer using compresed air and forgetting to cover the caliper with a rag so it shoots across the garage when it pops out.  ::)
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline ST1100
« Reply #5 on: July 17, 2016, 08:59:50 PM »
LOL! Ditto (on the compressed air... even build an adaptor-hose), but I first shim out the calliper with a selection of wooden strips...  ;)
STOC #637
Offline Green1
« Reply #6 on: July 17, 2016, 10:01:47 PM »
Why didn't I think of that to obvious I suppose   ;D
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #7 on: July 17, 2016, 10:06:52 PM »
After doing one on a CX500 with compressed air and forgetting to take my hand out the way, found it much safer with a grease gun ;D
Offline Green1
« Reply #8 on: July 17, 2016, 10:20:29 PM »
It doesn't go with the same exciting bang though
I'm also to tight to waist the grease  ;D
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #9 on: July 17, 2016, 11:06:22 PM »
Assuming you are replacing the seal, I just heat the alloy body with a Mapp gas torch and then tap the housing sharply onto a flat steel plate to free the piston off. Has worked fine for the last 3 calipers I stripped. These were the original Honda ones as fitted to 400/4, /250/360G5/500/4 & 750/4 though.
« Last Edit: July 18, 2016, 08:01:19 AM by AshimotoK0 »
« Reply #10 on: July 18, 2016, 08:24:19 AM »
I use and old master cylinder and hose. Fill it with brake fluid and pump till it pops out. Comes out a bit more gently than compressed air but is a messy job with the fluid running out at the same time as the piston.
