Author Topic: Turning 550 carbs into 500?  (Read 2893 times)
Offline Honda Al
« on: June 28, 2016, 07:34:21 PM »
Hi all,
After looking for information on this I just want to clarify - can I turn Keihin carbs 069A (550) into a Keihin carb 627B (500) by just changing the internals? jets, pilots, etc. The bodies, fittings, etc. are the same across the two models?
Thanks, Alan
« Last Edit: June 28, 2016, 07:50:09 PM by Honda Al »
Re: Turning 550 carbs into 500?
« Reply #1 on: June 28, 2016, 07:45:03 PM »
There's virtually no difference between the sets. The main jet size is the only major difference as far as I'm aware.
Offline Honda Al
« Reply #2 on: June 28, 2016, 07:49:16 PM »
Thanks James.
Did you get my message about the exhaust I've imported south for you from Steve?
« Reply #3 on: June 28, 2016, 09:26:45 PM »
Hi Al - no, but I'll check my Pm in a moment. Running a little behind on all fronts at the moment...
