Author Topic: Wanted - Recommendations for Vacuum Balance Gauges (CB750F1)  (Read 14247 times)
jimv50
Re: Wanted - Recommendations for Vacuum Balance Gauges (CB750F1)
« Reply #15 on: July 01, 2016, 05:34:22 PM »
I however will be having a go at making something like this  ;D
Offline gtmdriver
« Reply #16 on: July 01, 2016, 09:00:17 PM »
I just used the standard tank with an extension fuel tube standing on a nearby box.
As Oddjob says balancing the carbs is the very last job after you've set up the ignition and the valve clearances.
Offline Zunspec
« Reply #17 on: July 02, 2016, 08:24:33 AM »
As I know how clumsy I can be a seperate purpose fuel supply is probably a wise choice  ;D
I don't want to knock this tank onto the floor.
Cheers  Geoff
jimv50
« Reply #18 on: July 03, 2016, 03:18:49 PM »
After trying in B&Q and other shops for the bits necessary and been underwhelmed by the cost I have ordered a Morgan Pro carbtune for £71 including pouch, packing and postage
« Reply #19 on: July 03, 2016, 03:34:37 PM »
I've got a Davida set and they are very good imho. Small amount of bounce but nothing major at all.
Offline Zunspec
« Reply #20 on: July 06, 2016, 03:56:33 PM »
Thought I should post that the carb synchronisation was successful  ;D  It turned out to be a fairly easy process with the appropriate kit.  Of course I lost two of the washers when I first undid the vacuum blanking screws and now have to file a 4mm washer out to 5mm so I get a good seal, but that's about par for me  :D
Follow the link to a short video:
https://www.flickr.com/photos/zunspec/27514413164/in/album-72157655896677392/
Cheers  Geoff
« Reply #21 on: July 06, 2016, 04:56:16 PM »
Those washers are soft aluminium to seal not steel
Offline Zunspec
« Reply #22 on: July 06, 2016, 05:13:21 PM »
Hi Bryan,
I used some soft copper ones (after annealing) so should be OK.
Cheers  Geoff
