Author Topic: Help! Dead bike.  (Read 11358 times)
Re: Help! Dead bike.
« Reply #15 on: July 02, 2016, 07:03:40 AM »
If you're correct Mike, that's 15 feet at 30mph (44fps)
Never thought of it like that.
Has anyone ever considered how long it takes before the indicator bulb comes on after you press the switch? I seem to remember that it's a lot longer than that.
Offline Chris400F
« Reply #16 on: July 02, 2016, 10:13:08 AM »
Does the actual delay really matter, as long as we're not talking of seconds of delay?
There is a relay involved so I'd have thought it's likely to be longer than with the simple switch arrangement of the brake light.
« Reply #17 on: July 02, 2016, 12:19:12 PM »
There's no relay with the brake lamp.  Have a look at the circuit diagram.
Every millisecond counts when it comes to braking.  With some drivers, thinking distance is way too long and they need as much notice of braking as possible.
Offline Chris400F
« Reply #18 on: July 02, 2016, 12:54:46 PM »
Thanks Mike, but I realise that, that's why I referred to the 'simple switch arrangement of the brake light'.
When I talked of a relay I was referring to Steve's previous post about the indicator, although reading again maybe his use of the words 'indicator bulb' confused things slightly.
I read it as referring to direction indicators where there most definitely is a relay and things won't happen instantly, but a delay before things happen isn't so critical.
Apologies I if have confused the issue.
« Reply #19 on: July 02, 2016, 01:13:50 PM »
No worries,  I haven't had enough coffees either.
« Reply #20 on: July 02, 2016, 01:17:11 PM »
I don't think the delay matters either way, most of the time dickhead car drivers don't even see or notice there is a bike there, so you've no hope of them taking notice of lights on one! :o
« Reply #21 on: July 02, 2016, 05:29:39 PM »
BMW drivers don't notice Transits either
Yes, that was me that got clobbered.  Totally not my fault.
« Reply #22 on: July 02, 2016, 06:40:06 PM »
bad luck Mike
 glad it was not you on your bikes,
  any truth in the rumour BMW are cutting their prices,
 they have found that  they can delete fitting indicators,as they never get used
« Reply #23 on: July 02, 2016, 07:03:14 PM »
Were you not aware the BMW is an instruction, Bend My Wing?
« Reply #24 on: July 02, 2016, 08:04:49 PM »
Thanks for sharing that.  I always thought it was Black Mens Wheels.
« Reply #25 on: July 02, 2016, 08:06:38 PM »
« Reply #26 on: July 02, 2016, 09:22:27 PM »
You sure it was wheels?
« Reply #27 on: July 02, 2016, 09:59:06 PM »
That's just what I was thinking Bryan 😁😁😁😁
« Last Edit: July 02, 2016, 10:15:55 PM by Nurse Julie »
« Reply #28 on: July 02, 2016, 10:38:06 PM »
I was being polite,  don't know why I bother.
