Author Topic: Oil pressure issue / motor rebuild  (Read 60139 times)
Re: Another oil pressure issue
« Reply #45 on: August 02, 2016, 01:46:26 PM »
Trigger, you have a pm.
Photo taken this morning with my beautiful assistants, Big Leigh on the left can single handedly lift an H-D 1200 motor into a car boot, so handy to have around. We each wrote a guess for the 'motor in' date on the garage wall. We expected a lot off faff after watching those clowns on the telly doing it, but it all came out suprisingly quickly and easily. 'Prior preparation prevents piss poor performance' as they told me when I was firing steam locos for a hobby.
We didn't resort to lifing the bike off the engine, because we couldn't be bothered taking off (and putting back on again) the wheels, and possibly the indicators, but did it the old fashioned way.
Eddie is an engineer, and will be providing calibrated micrometers, borrowed from work, and an ultrasonic bath for the carbs. It also did a lovely job on our coffeee machine's filter  8) .
« Last Edit: August 02, 2016, 02:52:53 PM by MrDavo »
« Reply #46 on: August 03, 2016, 09:42:54 AM »
Well I got the head off. Number 3 exhaust pipe has always been a little bit straw coloured, but I thought I'd fixed any air leak when I tightened up the inlet rubbers. Obviously not. I need to look at that carb - partly blocked main jet or fuel feed passage? Any other suggestions? The tappet gaps were right, btw.
The head gasket delaminated as it came off, while all looked clean and new in there, I think it was all put together a long time ago. The bores and pistons all look good so far, no visible wear.
The big PITA at this stage is that the barrel is reluctant to come unstuck. There doesn't look to be any jointing compound, but I'm nervous about using force. Tapping with a rubber hammer hasn't worked, I gave up and came in after a while. Any good suggestions?
Re: Oil pressure issue / motor rebuild
« Reply #47 on: August 04, 2016, 11:30:46 AM »
Futtocks! After going in the garage last night to strip my engine I have
!) Broken my workmate - off to B&Q soon to buy a real wood plank top, not the cr*p fibreboard it came with. It did say '100Kg weight limit', not sure what a CB750 motor weighs.
2) Wrestled with it on the floor and decided to invest in one of Trigger's engine stands.
3) Failed to get the barrels off. I may now wait until I can hold the motor securely, but I've tried the putting rope in the bore and the head back on (held with the 4 screws) and trying to turn it over trick. It didn't budge. I'm wondering whether to remove all the studs now. I've tried tapping with rubber mallet and wooden blocks, I'm scared of using extreme force though.
I also tried to buy an NP gasket set on eBay, but later the seller rang to say that the borrowers had been in the packet, so the order had to be cancelled. :(
« Last Edit: August 04, 2016, 12:02:01 PM by MrDavo »
« Reply #48 on: August 04, 2016, 12:15:19 PM »
You can still strip the bottom end and get to the crank etc for inspection with barrels still on. I cant remember but there may be small recesses in the castings to get a pry tool in. Sounds like butchery I know but sometimes you will need to do it. Trigger/Bryan/Oddjob will know they are the pros's on here.
« Reply #49 on: August 04, 2016, 03:26:16 PM »
I wouldn't  take any of the barrel studs out unless you are replacing them, or need to for any other reason. You'll give yourself a big headache if you get into that.
You can try to gently,  using a rubber block, or something similar,  to tap the top of the barrels first forward and then backward to see if they will release from the gasket and dowels. It's not much but just enough to break the adhesion at the base. Right at the top level with the head gasket surface so you are in effect using the barrels themselves as a lever to rock them loose while not putting any up or down blows onto the fins as they will snap.
The studs should not ordinarily be holding anything as they are all waisted down their whole length and so generally have clearance for the barells.
« Reply #50 on: August 04, 2016, 09:06:06 PM »
You could always get someone with strong arms to lift the engine by the barrels about a inch off the ground and then tap the crank case with a plastic/rubber mallet.
« Reply #51 on: August 04, 2016, 09:45:18 PM »
Sounds like a job for Big Leigh, from the photo at the top. Just come in from more ineffectual tapping and prying, no joy, that bugger is stuck - I was even considering using man's red fire.
« Reply #52 on: August 09, 2016, 12:08:27 PM »
My engine stand arrived, thankyou Graham, the motor is in it now, all very smart and stable.
The barrels are well and truly stuck, the problem is time, rather than corrosion, but how the heck do people strip the projects are are rusted solid - my pistons are free but it still won't shift one iota!
No stand here, but this is me attempting to use  gravity, with a ratchet strap hooked in the cam chain tunnel and to the garage roof beam. Its only a concrete garage< I got the engine swinging about, beat it around with a rubber mallet - later attempts included studs out and heat on the dowels in the front corners, also an attempt with a pallet knife. I gave up before I pulled the garage down from within!  :o
I'm minded to give up before I do real damage and seek professional help, though I'm not sure who from yet. My local garage says I can use their hoist, but the guy worries that I'd break the cases or barrels before it pulls apart mechanically.
« Reply #53 on: August 09, 2016, 12:56:11 PM »
Hi Oddjob, in desperation I took the studs out last night, I didn't mark them as I used 2 head bolts tight against each other on each stud to wind them out. I had put penetrating oil down first, but I saw no corrosion on the studs, There were a couple of 'pings' that made me think things were tight down there,  but I'm no better off. I pushed the loose studs through a card so I can keep track of which is which.
The head and rocker gaskets totally delaminated, leaving half on each surface. I think the base gasket wants to do the same, but can't.
Stripping with the barrels on is a last resort, but I wouldn't fancy reassembling it that way. I've doe a bit of prying here and there but bottled it before I do significant damage.
« Reply #54 on: August 09, 2016, 02:03:12 PM »
Before I try that, a friend who's in the bike trade suggests a chemical attack first - either thinners or Loctite 7200 Gasket Remover. As the head and upper barrel is such a mess I think I will get some.
« Reply #55 on: August 10, 2016, 12:55:27 AM »
I eventually took it apart anyway, barrels well and truly stuck on, pistons and rods still in the bores. I stupidly popped a ring out, I had to weasel it back in with my fingernails, which took ages.
Entry, risking the garage roof again with a ratchet strap. Note Trigger's stand coming in handy. Also the Aldi work bench's compressed cardboard top has been replaced with some proper wood after an, er, accident.
First glimpse of a main bearing:
Strangely although all the mains are toast, shells and crank, the big ends are fine, so I don't need any rods, Ash, I may need a rotor and ring gear yet, though, that big bolt isn't for shifting.
Oh, the horror!
I should cable tie up the rods, so they don't flop around and ding the pistons.
« Reply #56 on: August 10, 2016, 07:41:18 AM »
Those shells are toast, you should never be able to see the copper, and with that i suspect the crank is as well
« Reply #57 on: August 10, 2016, 08:07:12 AM »
Plus 1 with Bryan, that crank is toast. That's what happens when the previous owner ignores the essential oil change regime. Crank can be repaired but probably easier and cheaper to find a replacement.
« Reply #58 on: August 10, 2016, 08:21:15 AM »
There is a big problem I see in the photos, apart from the crank and shells, why is it so clean inside ? Not a oil stain in sight.
« Reply #59 on: August 10, 2016, 08:36:21 AM »
Your right that is incredibly clean. Pump failure do you think or maybe no restrictor jets fitted?
