Author Topic: CB750 MPG  (Read 5051 times)
Offline Mike on a bike
CB750 MPG
« on: July 21, 2016, 07:56:11 PM »
What would be an average MPG for a k6 CB750. My chop only has a 2 gallon tank and was wondering how far I would get on a tank full. I think I might have to change my speedo to one with a zeroable tripmeter.  :o
I'm not a complete idiot.....some parts are still missing.
Re: CB750 MPG
« Reply #1 on: July 21, 2016, 08:48:53 PM »
Most road tests of the time state about 30-35mpg, which by todays standards is shocking! The F2 with the super lean running pd carbs managed an average of 40mpg! It all depends on how hard or carefully you ride it, best I've ever seen on my 750F1 is 43mpg, steady 80mph on a clear (3am) M, but chances are with a chop you will have a smaller diameter rear wheel and lower gearing, therefore you'll get less mpg!
Offline MarkCR750
Re: CB750 MPG
« Reply #2 on: July 21, 2016, 08:53:41 PM »
Not a problem on a chopper though mike , you won't be going touring on it will you, the only issue you'll have is getting fed up with motorists asking you questions about it at petrol stops! 😄
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Offline Green1
Re: CB750 MPG
« Reply #3 on: July 21, 2016, 10:53:33 PM »
Yep 30-35mpg sounds about right.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Re: CB750 MPG
« Reply #4 on: July 22, 2016, 07:11:17 AM »
Both my F2's only manage low 30's as I have them set a bit rich. They run better.
Sent from my Nexus 6 using Tapatalk
Offline steff750
  • THE POWER OF DREAMS
Re: CB750 MPG
« Reply #5 on: July 22, 2016, 05:38:48 PM »
 ;) i must ride like a pussy my four cb750 k0's give just over fifty to the gallon
my sidecar unit is a bit thirsty but im sure that is doing well over forty to the gallon
i rarely go over seventy and prefer cruising at fifty to sixty and always go for long runs
Re: CB750 MPG
« Reply #6 on: July 22, 2016, 07:43:14 PM »
On a day out touring around Wales I got about 48 mpg from my CB750F1, mind you I am Mr Slow these days and stick to the speed limits.
Offline flatfour
Re: CB750 MPG
« Reply #7 on: July 22, 2016, 08:41:49 PM »
Both my CB750 (K2, US Spec) and CB500/4 (K1, UK Spec) return around 43 mpg with normal use. I try, however to avoid town riding (not too difficult in rural Norfolk). On the CB500 I change up at 6,000 rpm as a rule and cruise at 5,000 - 5,500 rpm. Similar speeds are adopted similar with the CB750, although engine rpm is obviously lower.
Offline Erling
Re: CB750 MPG
« Reply #8 on: July 23, 2016, 09:04:22 AM »
In the day I reckoned some 15 km/litre. About 40 miles  to the gallon?
No speedo connected  due to a 250mm Fontana 4 leading shoe drum bake conversion.
Distance covered between gas stations on the German motorways on week end trips to spectate at Moto GPs of the day gave an idea.
And the CB 750 used more than than the same capacity BMW and had only 18 litres to the 24 of the BMW!
In a days riding I came further on the 50 BHP BMW than the faster Honda!
Speed difference minimised after a few years. The BMW dropped an exhaust valve up through Germany from Italy.
More or less outside a BMW dealer. It was just to order a 67 BHP 90S engine!
And off we went even in the first place with the original 32mm vacuum carbs to the 38mm Dell Orto.
Erling.
Offline MarkCR750
Re: CB750 MPG
« Reply #9 on: July 23, 2016, 09:13:21 PM »
Hi Erling you mean that you fitted the engine immediately and continued your journey?, if I understood you correctly then you deserve great respect!
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
Offline Erling
Re: CB750 MPG
« Reply #10 on: July 24, 2016, 08:06:14 AM »
Sorry no had to ride pillion on friends BMW home.
Left all luggage on dealers workshop floor.
Only about 8-900 km still to ride.
Think we changed every tank fill.
Wait a fortnight for return in the Mini Cooper.
Took the dealer that long to get an engine.
But actually changing the engines was no big deal.
Had some practise from my first BMW an R69S.
That particular model had a vibrations problem!
After a couple of years a modified engine with a vibrations damper was introduced.
So I had 2 engines to swap every other year as they still had internal problems.
Since boyhood I had dreamed of a BMW. And indeed I still prefer it for long runs.
Wife too feel better on it for vacation trips to Italy.
Erling.
Offline MarkCR750
Re: CB750 MPG
« Reply #11 on: July 24, 2016, 09:27:04 AM »
Yes it's nice to have a low revving machine for long journeys, anyway welcome to the forum , cheers Mark.
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
