Author Topic: CB750 Barn find project - First Timer  (Read 272276 times)
Re: CB750 Barn find project - First Timer
« Reply #480 on: August 10, 2018, 09:19:59 PM »
Trig says drill it or put a tap down it and try and pull it out.
Offline Underdog1
« Reply #481 on: August 10, 2018, 09:27:40 PM »
Did consider drilling it but wasn’t sure if there was anything else to try first. Is the roll pin likely to be reusable after it’s been drilled?
« Reply #482 on: August 10, 2018, 09:30:17 PM »
No, there won't be much left of it. They are not available OEM anymore but I know Trig has a big trade pack of them in the engine building workshop.
« Reply #483 on: August 10, 2018, 09:31:37 PM »
Why put ANY gasket sealer anywhere other than the top to bottom crankcase joint? a smear of grease on the gasket, then if it needs to come apart again it wont trash the gasket, Honda recommend fitting them with NO sealant.
« Reply #484 on: August 10, 2018, 09:35:21 PM »
I bet Hondaman was responsible for the gaskets being flubbered, I think he says use gasket sealer.........😭😭😭
Offline Underdog1
« Reply #485 on: August 10, 2018, 09:44:32 PM »
Exactly that!
« Reply #486 on: August 10, 2018, 09:45:05 PM »
Bit of bad luck there Ud.... hopefully you can get it repaired. I have a mate who is a wizard at aluminium weld repairs but he is in Hull  :( ... But those type of repairs are def possible. Try to seek out somebody who specialises in that type of thing.. Good luck !
« Reply #487 on: August 10, 2018, 09:49:53 PM »
I would be welding that damage. Once the spring is under the correct tension it may break the rest of the case.
While the engine is out i would be investigating why the oil is not getting to the top end. It only takes a little sliver of Honda bond to block the oil ways and the jets. Check that you have all the correct 0'rings in place, as one missing or wrong size 0'ring will effect the oil pressure  ;)
Offline Green1
« Reply #488 on: August 10, 2018, 09:52:43 PM »
Never understood using sealant on gaskets. Why use a gasket if your going to use sealant?  ???
I always grease them even though it feels wrong its so right.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #489 on: August 10, 2018, 09:53:07 PM »
Almost every Honda engine we get sent from USA for overhaul needs major welding. Usually where the chain has made a massive hole in the cases, all need fin repairs and general casing repairs but Trig does it himself.
Offline Underdog1
« Reply #490 on: August 10, 2018, 09:59:09 PM »
If it’s getting to the oil filter but not up to the top does this narrow things down at all? Feel like I’m back to square 1 now if I strip the top end down again!
« Reply #491 on: August 10, 2018, 10:13:08 PM »
I feel your pain. But, from what you have said, the oil has only got from the pump to the filter. That is about 8 inches  :o
There is no point solving the kick start when you still have other issues.
Offline Underdog1
« Reply #492 on: August 10, 2018, 10:20:24 PM »
I’m going to do some more reading on this, there’s a lot of threads out there with people struggling to get pressure after a rebuild and have got round it by fillin from the oil gallery plug on the rhs and pouring lots of oil in the top end. One suggested spending 15 minutes running the starter on and off to build sufficient pressure and some others said they just had to run the engine to get pressure as nothin else worked! Be nice to have a bit more assurance than a suck it and see approach  :o
« Reply #493 on: August 10, 2018, 10:35:19 PM »
Don't believe everything you read, when it comes to getting pressure up on these engines. Never do it off the starter motor, it will burn it out. Never put oil in the top end, as you will never know if oil is getting there, if it is already put there.
Over the years i have built more than 200 of these engines and i have never failed to get full pressure. I have rebuilt a lot of engines were people have failed to get pressure  ;)
As Bryan and Oddjob will tell you. We call most of these people Sunday mechanics in the trade. They will be in Halfords on a Saturday, try to fit the parts on the Sunday and would be in our workshops on the Monday, asking what went wrong and could we sort it  ;D ;D
You have just got to get in there and get it right. The pro advice is here on this forum  ;)
« Last Edit: August 10, 2018, 10:42:44 PM by Trigger »
Offline Underdog1
« Reply #494 on: August 11, 2018, 01:47:00 PM »
Don’t suppose JB weld would have its place in this sort of repair (obviously clutching at straws here!)
