Author Topic: Cam end cover leak!!!  (Read 4694 times)
Offline sam_vfr
« on: July 25, 2016, 11:24:43 AM »
Hi All.  Don't know if anyone has any tips on this as its driving me mad!
I have a leak from both sides of the cam cover plates.  I've tried replacing the  O rings and even a little silicon, but nothing seems to be stopping it.
Any other ideas/recommendations would be appreciated.
Sam
Re: Cam end cover leak!!!
« Reply #1 on: July 25, 2016, 05:52:51 PM »
There needs to be a soft alloy sealing washer between the steel bracket that the end cap screws onto and the top cover as the oil can come out of the bolt hole
« Reply #2 on: July 25, 2016, 06:02:22 PM »
Try some PTFE tape
« Reply #3 on: July 26, 2016, 07:15:23 AM »
PTFE  NEVER
« Reply #4 on: July 26, 2016, 07:32:16 AM »
What's wrong with it?  I use it all the time at work.
Offline gtmdriver
« Reply #5 on: July 26, 2016, 08:37:14 AM »
When I bought my CB350F I thought that there was a leak from the cam cover joint but it turned out to be coming from one of the chrome bolts on the end of the rocker shaft. The alloy crush washers can be replaced by Dowty washers which have an integral O ring seal and do a much better job.
« Reply #6 on: July 26, 2016, 09:12:04 AM »
ptfe is fine for gas and water but not on a honda
« Reply #7 on: July 26, 2016, 09:54:49 AM »
You could also check the crankcase breathers to make sure you aren't trying to contain any pressure build up.
Offline mickwinf
« Reply #8 on: July 26, 2016, 04:05:23 PM »
I reckon oddjob is correct, I had a similar leak on my 500, if you take the endcaps off you will see the little L shaped bracket that is held on to the head by a single 10mm bolt, with 2 washers, one below and one above the bracket. as Ken says it should be a soft alloy washer, I found a copper one did the same job and cured my leak.
« Reply #9 on: July 27, 2016, 06:23:29 AM »
I don't mind you taking the credit mate
Offline mickwinf
« Reply #10 on: July 27, 2016, 08:45:00 AM »
ha sorry Bryan, other experts are available!
