Author Topic: Console (idiot lights) cover wanted  (Read 7795 times)
Offline stevush
« on: August 01, 2016, 06:18:50 PM »
As above wanted please for CB400F. Must have all three lugs intact and be good condition. I have a tatty one already with broken lugs, looking for something better.
Steve
Offline Chris400F
Re: Console (idiot lights) cover wanted
« Reply #1 on: August 01, 2016, 08:59:34 PM »
Steve at 400fourbits (http://www.400fourbits.co.uk/) has an assembly that is decent but has been repaired - depends how bad yours is.
Also CB-Four.com do a repro assembly - not cheap and out of stock at the moment anyway.
However the page also notes that the same part is used on the CB 400 F, CB 550 F and K as well CB 750 K7+F1+F2 so you may be able to widen your search.
http://www.cb-four.com/cgi-bin/shop/__Pilot-assy---CB400F-CB550F-K-CB750K7-F1-F2CB400F-CB550F-K-CB750K7-F1-F2__15-0030-17_02.05.html
« Reply #2 on: August 01, 2016, 09:58:07 PM »
I have a crate full of those from 550 and 750's. Will have a look to see if they are the same as the 400.
« Reply #3 on: August 02, 2016, 07:26:44 AM »
Can't believe how many I have of these but, found a good one out of all the chipped / scratched ones.
Yours for the price of post and a donation to the site.
Offline stevush
« Reply #4 on: August 02, 2016, 08:41:52 AM »
Agreed Trigger, thanks
PM Sent
Regards
Steve
Offline Green1
« Reply #5 on: August 03, 2016, 10:01:34 PM »
Ooops havn't donated for awile
So now done  ;)
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #6 on: August 03, 2016, 10:32:19 PM »
Do you have another one please Trigger!
I had one on order from DS, they were getting a pattern one from the US but called me today to advise there are no more available and they have no plans to manufacture anymore in the near or distant future  :-[.
The one I have on 'Project 400/4' is cracked and has two broken lugs, the clocks are now fully restored and need a decent console to fit between them!
Happy to pay, I don't expect a freebie  :)
Dave
« Reply #7 on: August 04, 2016, 07:39:38 AM »
Dave
Sorry, but that was the only one I had in good condition. The rest have broken lugs. Did see a nice one at DK the last time I was there, are you aware that they are the same on the CB550 ?
Offline Piki
« Reply #8 on: August 04, 2016, 04:06:12 PM »
A friend of mine has one in good condition(I have it at home) send me a pm if you are interested.
Thank you.
Offline kent400
« Reply #9 on: August 04, 2016, 04:52:01 PM »
Using the incorrect screws and or over tightening causes broken lugs on these warning light covers. A while back in a few idle moments I tried a repair on one of these covers. It was a scrap one and I never finished a final 'tidy up' on the repair as  I had no intension to use the cover but clearly the repair would work.  Now a replacement is apparently no longer available it might be the only option.
I made some brackets in mouldable plastic and secured them using two part epoxy adhesive. Obviously the technique requires refinement particularly the top lug, the side ones can hardly be seen but the top one needs to tidy.
Offline stevush
« Reply #10 on: August 04, 2016, 08:05:25 PM »
Received mine today from Trigger, looks great, very pleased  :)
Steve
« Reply #11 on: August 05, 2016, 06:36:03 PM »
Once again, what a great site this is:-).
Trigger, thank you for looking and your reply.
Piki, Thank you and PM sent.
Offline Dave487
« Reply #12 on: August 09, 2016, 09:15:01 PM »
If anyone has all the bits from  broken or cracked ones can I suggest using an adhesive called Sci-grip SG5000-06. This is Toughened Methacrylate and I have used it successfully to repair the attachment lugs on my Yamaha which is made from ABS plastic. It will adhere really well to metal and plastics.
I buy small tubes from Glue Online. its not cheap but I found it worked really well and sets in 5 to 10 minutes.
Offline kent400
« Reply #14 on: August 20, 2016, 02:26:55 PM »
Looks like the cover is secured by csk wood screws rather than cross head ones and it looks like the top lug is split. The original screws are special ones designed for plastic their part number is: 9390224280 available from Silvers and they are black passivated. Silvers listing states they are 6x10 but that's confusing, well it is to me! Whilst the thread length is 6mm the head size is a number 8 I think. Maybe someone has a better knowledge of screw sizes as I've been asked for these on quite a few occasions and usually when they have found the are 63p each from Silvers. Add to that the P&P and it gets a bit excessive for 3 screws. To that end I'm trying to source screws of the correct type and no doubt they would be like 10p each if a box were bought. Anyone have any idea where to start looking? Incidentally quite a few other SOHC bikes use this console.
