Author Topic: Generator cover is this bad?  (Read 10587 times)
Re: Generator cover is this bad?
« Reply #15 on: August 02, 2016, 08:24:05 AM »
Thanks Trigger. David silvers here I come agin.
Is there supposed to be any oil in there at all for the pre engage or such?
Very good question. There is no crank seal on that side and there is about half a mm float from the case to the starter cog. I have seen alternator housings dry as a bone, some with a thimble of oil and one once that had over a litre of oil because someone put the seal in round the wrong way.
Offline onethumb
« Reply #16 on: August 02, 2016, 09:10:59 AM »
Thanks. Top information.
Can I change it without talking out the starter?
« Reply #17 on: August 02, 2016, 09:16:06 AM »
Yes!
Offline onethumb
« Reply #18 on: August 02, 2016, 09:20:56 AM »
Result. Cheers hairygit.
Part ordered.
Offline onethumb
« Reply #19 on: August 02, 2016, 10:28:56 AM »
Ordered the seal then remembered that I put the engine on its side while in the frame to remove it. Could that be the reason for the oil being in the generator cover?
I'll still change it while I've got it open but just wondering.
Also when changing the cover are there any do's and don'ts concerning the generator its self?
Offline yozzer74
« Reply #20 on: August 02, 2016, 04:11:20 PM »
We're is this seal mine was full of oil when I took the cover off .
Offline onethumb
« Reply #21 on: August 02, 2016, 04:37:30 PM »
Hi yozzer It's number 19 on the diagram
« Last Edit: August 02, 2016, 04:40:28 PM by onethumb »
Offline yozzer74
« Reply #22 on: August 02, 2016, 07:14:00 PM »
« Reply #23 on: August 02, 2016, 10:13:10 PM »
If you removed the engine on its side and lifted the frame off, it should of been on the points and clutch side. Not the alternator ;)
Offline onethumb
« Reply #24 on: August 02, 2016, 10:37:21 PM »
Hi trigger, that's what I did. I read all the stuff on here and then did what you all said. It's been so long I forgot which way up.
Has any one got the thread size of the bolt that holds the flywheel on. Or is there any one in wolves or Amersham who's got the removal tool that they could hire out.
« Reply #25 on: August 03, 2016, 06:23:03 AM »
Got one in Gloucester
Offline onethumb
« Reply #26 on: August 03, 2016, 07:14:52 AM »
Thank you for such a kind over Bryanj, I would love to drive over to you and pick your brain ( you've got fans all over fella) but by the time I've paid the fuel in the transit.
Where is the cheapest supplier out there?
« Reply #27 on: August 03, 2016, 07:22:27 AM »
If you are going to work on all the fours get the genuine Honda one from Dave silver or any Honda dealer 07733-0020001 is the part number. if its a one off   i think M & P do one
Offline onethumb
« Reply #28 on: August 03, 2016, 07:28:39 AM »
Thanks bryanj, the m and p one might suit my purpose better. ( twin or a stroker next I think)
I'll get searching.
« Reply #29 on: August 03, 2016, 07:30:44 AM »
There are several listed on ebay but if going for a one model only make sure you get the SOHC one
