CB750
comstar wheel rim tape??
Topic: comstar wheel rim tape?? (Read 3545 times)
tarmac
Newbie
August 02, 2016, 01:38:27 PM »
do comstar wheels need a rim tape or band fitted......I have just removed the old tyre from my 1979 750 f2 ready to fit a new one and didn't find any rim tape there........should there be ?.....am I wrong in thinking that they are just for spoked wheels and are not required.
cheers Terry
ride safely,have a nice day
stevush
SOHC Member
Re: comstar wheel rim tape??
August 02, 2016, 01:44:30 PM »
I think the rim tape is only there to prevent spokes puncturing the inner tube, in your case its not needed
Regards
Stev
tarmac
Newbie
August 02, 2016, 01:52:51 PM »
thanks for that quick reply Stevush just as I thought but wanted to make sure before I go ahead ,..much appreciated,.Terry
royhall
Keep biking I'm not quite bankrupt yet
August 02, 2016, 04:18:29 PM »
You don't even need a tube with many ComStar wheels. Should be able to run tubeless with tyres like Avon Road riders. My 1978 F2 is tubeless.
Sent from my Nexus 7 using Tapatalk
tarmac
Newbie
August 02, 2016, 07:00:37 PM »
how do I do that Roy,.....where can I get a suitable tubeless valve to fit.
mike the bike
CB400F, Royal Enfield Interceptor.
August 02, 2016, 07:30:13 PM »
The tyre fitters usually have a selection of them.
August 03, 2016, 06:22:00 AM »
Check the writing on the rim as if it does not state tubeless it is not suitable
tarmac
Newbie
August 03, 2016, 09:30:15 AM »
just checked the rim for numbers,....the numbers are D.I,D JAPAN 2.15 X 18 and J18X2.15 117 DOT at another location.
so it's tube only then.
thanks again for the information,..Terry
royhall
August 03, 2016, 10:30:10 AM »
Some Comstars wont take the tubeless valve so will need to run tubed. You wont need the rim tape whatever as you dont have spokes. If your unsure about the rim just fit a tube.
August 03, 2016, 02:38:26 PM »
Having jogged the memory it's fairly easy to tell:-
If the valve on the tube is a non sloppy fit in the hole it's a tubed rim
If the valve has a lot of play it's a tubeless and needs a special nut to hold the tube
tarmac
Newbie
Reply #10 on:
August 03, 2016, 05:53:22 PM »
using that information you have just given Bryanj I have just measured the hole size and valve size and they are as follows.... 8.3 mm hole and 7.5mm valve,
cheers Terry
CB750
