Author Topic: comstar wheel rim tape??  (Read 3638 times)
Offline tarmac
« on: August 02, 2016, 01:38:27 PM »
do comstar wheels need a rim tape or band fitted......I have just removed the old tyre from my 1979 750 f2 ready to fit a new one and didn't find any rim tape there........should there be ?.....am I wrong in thinking that  they are just for spoked wheels and are not required.
                        cheers Terry
ride safely,have a nice day
Offline stevush
Re: comstar wheel rim tape??
« Reply #1 on: August 02, 2016, 01:44:30 PM »
I think the rim tape is only there to prevent spokes puncturing the inner tube, in your case its not needed
Regards
Stev
Offline tarmac
« Reply #2 on: August 02, 2016, 01:52:51 PM »
thanks for that quick reply Stevush  just as I thought but wanted to make sure before I go ahead ,..much appreciated,.Terry
« Reply #3 on: August 02, 2016, 04:18:29 PM »
You don't even need a tube with many ComStar wheels. Should be able to run tubeless with tyres like Avon Road riders. My 1978 F2 is tubeless.
Sent from my Nexus 7 using Tapatalk
Offline tarmac
« Reply #4 on: August 02, 2016, 07:00:37 PM »
how do I do that Roy,.....where can I get a suitable tubeless valve to fit.
« Reply #5 on: August 02, 2016, 07:30:13 PM »
The tyre fitters usually have a selection of them.
Online Bryanj
« Reply #6 on: August 03, 2016, 06:22:00 AM »
Check the writing on the rim as if it does not state tubeless it is not suitable
Offline tarmac
« Reply #7 on: August 03, 2016, 09:30:15 AM »
just checked the rim for numbers,....the numbers are   D.I,D  JAPAN  2.15 X 18    and    J18X2.15  117 DOT   at another location.
  so it's tube only then.
   thanks again for the information,..Terry
« Reply #8 on: August 03, 2016, 10:30:10 AM »
Some Comstars wont take the tubeless valve so will need to run tubed. You wont need the rim tape whatever as you dont have spokes. If your unsure about the rim just fit a tube.
Online Bryanj
« Reply #9 on: August 03, 2016, 02:38:26 PM »
Having jogged the memory it's fairly easy to tell:-
If the valve on the tube is a non sloppy fit in the hole it's a tubed rim
If the valve has a lot of play it's a tubeless and needs a special nut to hold the tube
Offline tarmac
« Reply #10 on: August 03, 2016, 05:53:22 PM »
using that information you have just given Bryanj I have just measured the hole size and valve size and they are as follows.... 8.3 mm hole and 7.5mm valve,
 cheers Terry
