Author Topic: Ignition Timing Question 500 Four  (Read 2578 times)
Offline paulbaker1954
« on: September 09, 2016, 05:05:07 PM »
I just restrobe checked my timing and to get the timing marks to line up for 1 and 4 I have had to rotate the main plate as far as it will go anti-clockwise.
This seems a bit odd - have I done something stupid somewhere?
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Re: Ignition Timing Question 500 Four
« Reply #1 on: September 09, 2016, 05:07:37 PM »
Which marks were you using, T or F?
« Reply #2 on: September 09, 2016, 05:11:59 PM »
F
« Reply #3 on: September 09, 2016, 06:01:06 PM »
The F mark is for STATIC timing, ie engine NOT running, there are other marks ( little lines) for dynamic timing, you have to check in your manual as to which to use.
« Reply #4 on: September 09, 2016, 07:48:00 PM »
on the timing plate you will   "   lines,
 if your using Boyer electronic,these should line up at 4,500rpm and over,when you use the strobe,
 I would hilight the marks using a dab of Tippex,
