Author Topic: Rough Running advice needed -- at wits end  (Read 7181 times)
Offline gordo
Re: Rough Running advice needed -- at wits end
« Reply #15 on: October 14, 2016, 11:36:01 AM »
Cheers for that great description Paul, guess I'm in the garage this weekend.
Offline Rob.b (Rob Birkett - RIP)
« Reply #16 on: October 15, 2016, 10:10:19 AM »
What happened to the float? looks to be only half there. I found one in an old tin earlier this week if it's any use, along with a complete slide, needle and arm. No idea why they were there.
The float was seized and broken when I was given the carbs, which is why they have sat around for so long, if I ever get to the position where I know how they work and want to reassemble them I may well take up your offer, but for their own safety your spares are probably best with you.  After all who knows what the Aliens are capable of once they know I am figuring out their technology. 😊
By the way there are two short perforated tubes that I think the parts list refer to as jets, are these also known as emulsion tubes, if not where is the emulsion tube (s)? Or is it that the emulsion tube is part of the jet.
Cheers Rob
« Last Edit: October 15, 2016, 10:27:18 AM by Rob.b »
