Author Topic: Front brake woes  (Read 6698 times)
Offline cb550k-aaron
Front brake woes
« on: September 28, 2016, 10:20:26 AM »
Little or no resistance in the lever. Caliper been rebuilt and the master cylinder redone too. Bled etc but not working properly
Sent from my SM-G920F using Tapatalk
Re: Front brake woes
« Reply #1 on: September 28, 2016, 11:32:41 AM »
when you say no resistance,do you mean it come to the bar with nothing happening? or its just very spongy,or soft.
 you could try a reverse  purge,take the pads out,pump the brake untill the piston is almost out,then carefully use a G clamp to
push the piston back,it may flush any air out of the master cylinder,
 good luck,and be careful of the brake fluid,it kills paintwork
« Reply #2 on: September 28, 2016, 11:36:41 AM »
Very soft and spongy mate. It does work but not great at all wouldn't be safe like
« Reply #3 on: September 28, 2016, 12:26:49 PM »
Tape the lever up to the grip and leave it for a couple of days.
Works for me.
« Reply #4 on: September 28, 2016, 12:33:03 PM »
Paul will give that a try
« Reply #5 on: September 28, 2016, 03:58:59 PM »
I don't have a Mud guard on as I have converted to a Café Racer. Do u have any pics showing what it should be?
« Reply #6 on: September 28, 2016, 04:34:45 PM »
Two things
bleed just the master first, i have put up a description on here before
With no front guard you need a fork brace or the forks will flex all over the place and handling will be crap
« Reply #7 on: September 28, 2016, 04:36:55 PM »
Oh really I didn't realise that tbh. I'll look into one. Can one be bought or does it have to be made?
« Reply #8 on: September 28, 2016, 05:10:43 PM »
Either.  There's 1690 to choose from on ebay.
« Reply #9 on: September 28, 2016, 05:10:52 PM »
If you have an old tatty mudguard you can remove the centre brace and use that to mount your "sporty" guard, you have to have some sort of mudguard to pass MOT
« Reply #10 on: September 28, 2016, 05:13:07 PM »
carefull with ebay as the not so old 500 twin (and i dont mean the T) was also a cb 500 and a lot of sporty parts are made for those
Offline Lynx
  • Repair & Despair Under One Roof
« Reply #11 on: September 28, 2016, 10:13:18 PM »
Aaron,
Have you tried sucking the fluid through from the bleed nipple with a vacuum?
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
« Reply #12 on: September 28, 2016, 10:28:29 PM »
Aaron,
Lynx.
Yes mate. All air out of it too
Offline Lynx
« Reply #13 on: September 28, 2016, 10:30:09 PM »
Well done 😊.
Sent from my HTC Desire 530 using Tapatalk
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
