Author Topic: Help Needed for Crank case repair  (Read 3077 times)
Offline MeilakJ
  • Life is what you make it!!
« on: October 02, 2016, 05:35:02 PM »
HI All ,
JUst need some advice regarding a quick repair for a chain damage to a lower case on the cb 750
Is there any type of chemicals that will keep up the repair ?
Any ideas welcome  :)
Offline RGP750
Re: Help Needed for Crank case repair
« Reply #1 on: October 02, 2016, 06:48:56 PM »
Devcon epoxy will do it but it will need completely
de greasing
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
« Reply #2 on: October 03, 2016, 08:29:06 AM »
de greasing
You nasty man RGP. Alloy weld it up if you have the casing parts or  K6 crank cases are easy to find.
« Reply #3 on: October 03, 2016, 08:41:15 AM »
de greasing
No he isn't Honda used aluminium filled epoxy in my 69K0 engine to blank off a drilling and seen it on other engines  ;D ;D I once used it to make a big mould that compression moulded rubber parts at around 180° C and we made 500 pieces from it and it was still going strong afterwards. You need the right stuff though.
« Last Edit: October 03, 2016, 08:45:19 AM by AshimotoK0 »
« Reply #4 on: October 03, 2016, 08:55:08 AM »
de greasing
The damage cased by a chain on a 750 is usually a big hole that some I have fitted my fist in, plus all the hairline cracks that will weep oil after any half hearted repair.
Offline RGP750
« Reply #5 on: October 03, 2016, 11:12:15 AM »
While i agree not the perfect solution, if
done PROPERLY will last a life time.
If you are stripping the engine totally yes weld it.
I wouldn't expect to repair a hole the size of your fist either Trigg.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Offline MeilakJ
« Reply #6 on: October 03, 2016, 07:04:11 PM »
Thanks for your input guys !!
I think best option would be to replace crankcase .Managed to find a good priced one but just  need to check locally for registration purposes .
At the moment there is like a copper plate covering the damage which I have not yet removed to see underneath. One i take it off I will have a better view.For is that oil leaks from it .
