Author Topic: 500 clutch activation cover  (Read 4311 times)
Offline RGP750
« on: October 13, 2016, 06:44:37 PM »
Hi All
Just started to do some work on the 500 and took off the Clutch actuation cover and found
the center boss in pieces.
Anyone have a spare lying around please.
Rich
« Last Edit: October 13, 2016, 06:57:40 PM by RGP750 »
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline RGP750
Re: 500 clutch activation cover
« Reply #1 on: October 14, 2016, 06:50:54 AM »
Thanks Oddjob
That's good to know, let's give it a few days to see if anyone else
has one.
Thanks  a lot Rich
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Offline RGP750
« Reply #2 on: October 14, 2016, 12:26:20 PM »
Hi Oddjob
After 59 views looks like you are my only hope.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Offline RGP750
« Reply #3 on: October 15, 2016, 06:58:56 AM »
Hi Oddjob
Yes it is the cover, the boss the worm gear runs in is broken in the casing.
Rich
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Offline RGP750
« Reply #4 on: October 15, 2016, 10:24:50 AM »
Ah I'll take a deeper look, The slotted adjuster on the outside is pretty poor and stuck
does it remove from inside out? should it just tap out? i haven't tried yet,
Ah just cleaned some of the crud off and yes it's the worm screw boss.
How available are they????
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Offline RGP750
« Reply #5 on: October 15, 2016, 01:01:10 PM »
Hi Oddjob ,Yes you are right ,the worm housing.
Got it out.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
« Reply #6 on: October 15, 2016, 07:32:23 PM »
Hi Rich if you get really stuck & you need to get out and ride the bike I will loan you the one from my K0  That's assuming that its the same part ... which Odjob or Trigger or Bryan will tell me   :D
Offline RGP750
« Reply #7 on: October 15, 2016, 08:20:52 PM »
That's really good of you Ash, what a great forum this is.
Not to worry Oddjob i won't pinch your spares i have just found out
DS has 2 in stock at not too bad for what it is just over £20
Thanks for pointing me in the right direction Oddjob.
Cheer Guys Rich
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Offline RGP750
« Reply #8 on: October 16, 2016, 08:17:55 AM »
Thanks Oddjob.
up and running soon ;)
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
