Author Topic: cheap ultrasonic cleaner  (Read 13417 times)
Re: cheap ultrasonic cleaner
« Reply #15 on: October 19, 2016, 09:47:49 PM »
Well I got licorice allsorts for fathers day. 🤔
« Last Edit: October 19, 2016, 09:50:36 PM by royhall »
Offline Glenzil
« Reply #16 on: October 20, 2016, 09:04:06 AM »
yes i did leave the enulsion tub inserted! well spotted. :D I had a go at getting one of them out and it was well and truly stuck, so its a job for another day, but definitely must come out and be cleaned before they go back together.
Current Bikes:
Kawasaki GT750P1 1982
Honda CB400F 1977
« Reply #17 on: October 20, 2016, 09:21:52 AM »
You need a bit of 4mm dowel and go in from the top. Place the dowel on the tube and tap it out.
Offline Glenzil
« Reply #18 on: October 20, 2016, 04:43:29 PM »
Tubes are out now - bit of heat and some WD and a thin bit of dowel
Current Bikes:
Honda CB400F 1977
Offline ManicGTI
« Reply #19 on: October 24, 2016, 05:26:09 PM »
I think I will just stick with using the dishwasher or if there really bad boiling them on the hob with a dishwasher tab as its not failed yet.
Mick
May have to try this!
Offline Green1
« Reply #20 on: October 24, 2016, 10:08:34 PM »
You can always clean the dishwasher out afterwards  ;)
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline ManicGTI
« Reply #21 on: October 29, 2016, 05:14:52 PM »
If the dishwashers working properly, it'll flush it all out!  Most of them are clogged with crap mind..
« Reply #22 on: October 29, 2016, 06:30:44 PM »
I repair commercial dishwashers for a living and I find a lot that are clogged with crap.
« Reply #23 on: October 30, 2016, 09:03:58 AM »
You really need to instruct the owners that dishwashers ain't toilets!!!
« Reply #24 on: October 30, 2016, 09:41:19 AM »
Already done
Offline paulbaker1954
« Reply #25 on: October 31, 2016, 10:21:19 AM »
Just  to add my 3 cents. It is important to make sure thatt he internal passages are clear ESPECIALLY the idle circuit. Below is a description I posted a while ago of how I checked these were clear.
The idle circuit consists of 3 holes and the pilot jet.
hole 1 can be seen on the carb wall on the inlet side throat at 90 degrees from the top before the throttle slide, this actually joins in to the hole from the air screw by the way.
Hole 2 is a VERY small one at the base of the throat on the exhaust side at 180 degrees from the top just in front of the throttle slide. This is where the idle mixture is fed in to the cylinder.
Hole 3 is where the air bleed screw goes in.
At idle air is drawn from hole one and the air screw then adjusts the amount of incoming air, this is then mixed with fuel from the pilot jet To provide the idle mixture.
The resulting mixture then squirts out of the very small hole (hole 2) at the front of the throat in to the cylinder.
I found the best way to check for blockage in the whole pilot circuit is to remove the pilot jet and air screw and blow down the air screw hole and at the same time cover the pilot jet hole and the other 2 holes with some combination of fingers and thumbs. You can then lift a finger or thumb from each hole in turn and hear if you get air blowing through.
It's a bit like mastering playing the bagpipes but an effective way to check the circuit for blockage.
This may sound complicated but if you find the holes and study the plenum chamber in the base of the carb it's pretty obvious how it works.
Hope this helps fellow owners with idle/suspected blocked carb issues.
I must apologise for my lack of foresight in that I should have taken some pics whilst the carbs were off. If I take them off again in the near future I will post pics to show where the relevant holes are.
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline Pops400
  • I haven't a clue what I'm doing...
« Reply #26 on: October 31, 2016, 08:06:56 PM »
The mental image this has conjoured up has still got me chuckling...  ;D
And if I claim to be a wise man, it surely means that I don't know.
« Reply #27 on: October 31, 2016, 08:20:29 PM »
As I was reading it, my brain was already thinking of bagpipes before you mentioned it.  Uncanny, or was it the haggis I had for breakfast?
Offline ManicGTI
« Reply #28 on: November 01, 2016, 01:09:25 PM »
Thought i'd add that I ended up basic ally doing the above.  I simmered the carb bodies in a Dishwasher Tablet Stock for an hour or so (Missus loved that), then did the bagpipe routine through all the holes to work out what went where.
It seems to have done the job, I was about to send the carbs in for US but I'm inclined not too for the time being, bike now starts and runs.
Offline Pops400
« Reply #29 on: November 02, 2016, 07:53:45 PM »
 8) Saved some cash, then.
