CB750
Engine smoking
3
Topic: Engine smoking (Read 8326 times)
yozzer74
Engine smoking
October 17, 2016, 02:04:15 PM »
Hi I've just done about 20 miles on bike noticed she smoking a lot .I thought it may have been because of just rebuilding engine .but I think it's getting worse .it's kicking a little oil out of the breather pipe on crank case too .video attached
https://youtu.be/jGkBzsxAnXE
yozzer74
Re: Engine smoking
October 17, 2016, 02:06:10 PM »
Any ideas what's wrong
philgresty
SOHC Associate
Re: Engine smoking
October 17, 2016, 03:23:21 PM »
looks like piston ring blow by to me. did you replace the piston rings with the rebuild?
yozzer74
Re: Engine smoking
October 17, 2016, 03:38:49 PM »
Yeah I changed rings new valve guides seals recur seats
MrDavo
Re: Engine smoking
October 17, 2016, 03:42:22 PM »
The rings might just need bedding in, don't tear it down again just yet.
yozzer74
Re: Engine smoking
October 17, 2016, 03:45:44 PM »
Do we think putting different oil in will help
tom400f
Re: Engine smoking
October 17, 2016, 04:06:49 PM »
20 miles today or 20 miles since rebuilding it?
What is the colour of the plugs? Consistent across all cyls?
What oil are you using? Doubt it will make any difference. Just to say I am using the Europarts semi-synth diesel stuff discussed on here without any apparent problems.
Edit: Watched the rebuild video - must say, lovely work.
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Re: Engine smoking
October 17, 2016, 04:07:17 PM »
what oil is in it?
Johnwebley
Re: Engine smoking
October 17, 2016, 04:15:22 PM »
after an engine rebuild,you should use the most basic mineral oil,
it helps the motor bed in,also a bit of firm acceleration and then shutting the throttle helps the ring to seal,
the smoke looks either the pump is not scavenging ,or the rings are not bedded in,or the valve stem seals are leaking
check the plugs,see if they all show oily tips,
yozzer74
Re: Engine smoking
October 17, 2016, 04:21:44 PM »
The plugs are black .this is the oil [ Guests cannot view attachments ]
K2-K6
Re: Engine smoking
Reply #10 on:
October 17, 2016, 04:39:01 PM »
Did you prep the bores at all by glaze busting them to allow running in of new rings?
Johnwebley
Re: Engine smoking
Reply #11 on:
October 17, 2016, 04:51:17 PM »
try a basic oil,
the better oil prevents the parts bedding in,
http://www.sparesworld.co.uk/10w40-Mineral-Engine-Oil-5ltr.html
you may find it cheaper,but don't use any synthetic till the motor is well run in
philgresty
SOHC Associate
Re: Engine smoking
Reply #12 on:
October 17, 2016, 04:52:50 PM »
looks like car oil, might not be the best for the wet clutch in your cb.
yozzer74
Re: Engine smoking
Reply #13 on:
October 17, 2016, 05:27:02 PM »
I had bores crossed hatched I think they call it .yeah it's car oil
UK Pete
Re: Engine smoking
Reply #14 on:
October 17, 2016, 05:32:31 PM »
Hey yozzer, my F2 smoked like a pig after the rebuild, then after about 100 miles it started to run clear until nothing so it could just be bedding in, btw these old bikes really do f=ck with your head, it can be so frustrating, but stick with it fella
pete
Link to my Diecast K0 restoration
http://www.sohc.co.uk/index.php/topic,4827.0.html
Link to sandcast restoration
http://www.sohc.co.uk/index.php/topic,6862.0.html
3
CB750
Engine smoking
