Author Topic: Engine smoking  (Read 8638 times)
Greebo
Re: Engine smoking
« Reply #30 on: October 18, 2016, 10:50:02 AM »
Bryan j you mentioned before that you used Tesco diesel oil can you remember which one
Yozz'
My K6 had a complete rebuild much the same as yours, the guy who built the engine & the bike is "shit hot" with the 750 sohc engines, he is in Rotherham
When my bike was finished he put Motul 10w40 semi' synth', there was not a hint of any smoke, the only issues we had was the PD carbs getting them jetted & set-up right, during that time frame when we were playing with the jets needle settings etc I had a lot of running on 3 cylinders, then 2 cylinders,  & all this was going on whilst running it in, but it has not had any adverse affects at all on how the bike runs & performs, I have done nearly 2k on the bike now & still as clean as a whistle . I have changed the oil twice I now run on Motul 15w50 semi'
if you cant get it sorted have a chat to Steve who built mine he is on Alma Road Rotherham, his work shop is at the side of Motographics, it would be a good idea for you to pop over & see him just for some advice & he will be happy to help...its only a few miles away from where you are
« Last Edit: October 18, 2016, 10:52:52 AM by Greebo »
Offline yozzer74
Re: Engine smoking
« Reply #31 on: October 18, 2016, 12:07:29 PM »
Thanks greebo yeah it's not too far
Offline MarkCR750
Re: Engine smoking
« Reply #32 on: October 18, 2016, 05:09:45 PM »
By the way Yozzer, I assume the smoke is blue, and smells oily, that's what you'll get if your burning oil, if it's black it's an overly rich mixture, if it's a bit like steam it's water evaporating from the exhaust, if it's white you've got diesel in there! 😄
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Offline yozzer74
Re: Engine smoking
« Reply #33 on: October 18, 2016, 05:24:35 PM »
It's definitely oil you can see it on end of pipe
Offline MarkCR750
Re: Engine smoking
« Reply #34 on: October 18, 2016, 07:10:28 PM »
Sorry I only just saw the video, yes definitely oil smoke, fingers crossed that Pete's explanation proves correct, I had a CB900 years ago that smoked like that, it was worn valve guides, you could see the oil running down the valve stems!.
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
