Author Topic: Carb settings cb400f with 4-2 exhaust  (Read 8322 times)
Offline ka-ja
  • ken
  • yoshi 460
Re: Carb settings cb400f with 4-2 exhaust
« Reply #15 on: May 09, 2017, 04:40:02 PM »
Don't forget that fuel level alteration also effect the mix over the whole range, dropping the fuel level could result in too lean a mix when on larger throttle openings, needless to say very damaging to the top end. As already suggested, it may be more prudent to experiment with smaller pilot jets
nice bike,nothing in the bank
Offline Lynx
  • Repair & Despair Under One Roof
« Reply #16 on: May 10, 2017, 05:04:25 PM »
If it's just rich at idle all you have to do is open the idle air screws 1/4 turn.
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline Erwin83
« Reply #17 on: May 21, 2017, 06:42:42 PM »
Changed the float level to 24mm now..... And we've got reliable idle!
Also a nice coffee brown color on the plug.
Still with a hot engine (seriously hot), it drowns on pick up from idle to any throttle.
Will look into the air screws a bit see what that does.
Out playing with a bigger sister today:
CB466f - KTM 1190 advR
Offline Clem2112
  • Midlife
« Reply #18 on: May 22, 2017, 10:00:50 AM »
On the float bowl seal issue.
The ones I have used also swell up and grow 5mm in length but have not degraded visibly.
A few hours to dry out and they shrink and fit the groove again.
I must have fitted the same set many times and they have never leaked.
The fuel level (21 mm float height) is supposed to be a few mm below the joint face but the petrol will still wet the seal in normal use, banking over, accelleration or just through evaporation etc.
