Author Topic: Change the valve cover gasket without removing engine  (Read 4579 times)
Offline PHILIP2908
« on: November 20, 2016, 03:58:20 PM »
I posted about this before but couldn't find the thread.
Basically the 750 is a DK Special requiring loads of work and parts including a new head gasket. Engine removed, head skimmed, put together and ran fine; except for a big oil leak from front of the valve cover gasket. Apparently it is easy to put these on upside down and because the cam box is not symmetrical, it will leak - well Haynes never said 'owt about it.
Looking at it; the engine would have to come out again as the valve cover cannot be lifted off in situ. I couldn't face that as I've been in hospital having a new valve (heart) of my own so can't lift anything heavy - break the ribs again see. Ask Julie.
So I saw some chappie on You Tube change the gasket by undoing the 14 screws and lifting it up. So that's what I did (see photos if they made it through) and was fairly fiddly including having to remove the coils which was a right pain.
Just ordered a new genuine gasket off DS for £20 (WHAT !!), and will fit it and let you know the outcome.
1974 Honda XL250 K0 - Silver - owned for 32 years. Not running at the moment
1972 Honda CB750 K2 - Now candy apple red - Ex USA, a DK special - needs a lot more work than I thought - very quickly becoming a DS special...
Re: Change the valve cover gasket without removing engine
« Reply #1 on: November 20, 2016, 04:04:20 PM »
Hate to say this, but I can see you getting really pissed off with trying to get it over the can carriers and sprocket without damaging it, and £20 a time is a lot of cash to rip! Maybe you'd be better offering a mate or half sensible neighbour a few beers to help you out and back in with the engine, save a lot of cut fingers and swearing!
« Reply #2 on: November 20, 2016, 04:10:05 PM »
Don't lift anything heavier than a cup of tea......leave the engine alone for now, it will still be there when your fully recovered.
Offline Yoshi823
  • Biker to the bone...
« Reply #3 on: November 20, 2016, 04:31:57 PM »
I had to replace a leaking tacho drive oil seal & had to remove the engine just for that 50p seal  >:(
So I modified the frame not long afterwards
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Offline neilg
« Reply #4 on: November 30, 2016, 02:16:07 PM »
If it's any consolation I did the same many years ago. I managed to swop the gasket without lifting the engine out. It was very awkward and a friend is a big help so they can hold the cover and move it about whilst you fiddle, (there's a polite word), about with the gasket.
Good luck
Neil G
« Reply #5 on: December 01, 2016, 06:32:54 PM »
I got the tacho oil seal out without removing anything, after a very nice man on this forum told me how to do it by making a tiny hole in it, then using a self tapping screw. :)
Offline Menno
  • www.tanklackieren.de
« Reply #6 on: December 01, 2016, 09:54:04 PM »
I'm building a 750 now and I hope that this will make my life easier:
