Author Topic: Putting 750k6 barrels and head back on - any tips  (Read 2798 times)
« on: November 26, 2016, 04:07:17 PM »
Hi Guys
Going to put top end on this week - have built few 750 engines previously but they where the earlier k's so thought I would pick the brains of the experts - any tips for oil leak free assembly? Last K2 build using advice on extra thickness seals etc remains oil tight without even any misting.
Re: Putting 750k6 barrels and head back on - any tips
« Reply #1 on: November 26, 2016, 08:36:31 PM »
Are you sure its a K6  ;D If it is, then put it back together in the reverse order you took it apart. Honda had corrected all problems by the time the K6 came out.
« Reply #2 on: November 26, 2016, 09:15:06 PM »
Its got K6 engine no's and matches all the bits match CSML schematics Graham. nice and simple then - there was all kinds of suggestions for keeping the K2 oil tight so I'll just bolt it back together.
« Reply #3 on: November 26, 2016, 09:38:47 PM »
Yep, just put all 8 dowels in and all the rubbers ;) Just check the seal in the cam chain tensioner is OK, have never found the part number for that seal.
« Reply #4 on: November 26, 2016, 09:50:28 PM »
What seal do you mean Graham? I can't place that seal - just checked the schematics and can't see a seal except gasket?
« Reply #5 on: November 26, 2016, 09:55:55 PM »
It is there,( you will find it tomorrow) if it show no sign of damage it maybe OK.
« Reply #6 on: November 26, 2016, 10:04:24 PM »
I've fitted a complete new camchain train - where exactly does the seal fit within the tensioner Graham?
« Reply #7 on: November 26, 2016, 10:12:40 PM »
It's located in the tensioner housing and acts as a seal between the housing and the rod of the tensioner ;)
« Reply #8 on: November 26, 2016, 10:40:05 PM »
Just been in garage and see what seal you mean - not on schematics that I can see (part of housing part?)
Thanks for info
« Reply #9 on: November 26, 2016, 10:46:34 PM »
Phil, can we keep this 'our' secret, I don't want the whole world to know that seal is there  ;D ;D
« Reply #10 on: November 26, 2016, 10:51:21 PM »
I think the secrets out!
