Author Topic: CB350f Prinary Chain Guide  (Read 3856 times)
Offline H2Eric
« on: December 28, 2016, 01:27:45 PM »
Does anyone know which way round the two primary chain guides fit in the crankcases on a 1972 CB350f. The photo attached is the lower crankcase with the front of the engine at the bottom of the picture. There is a small hole at one end of the guide, which I assume is to signify which way round it fits, but I can find no reference to it anywhere. With a 50% chance of getting it right the question is have I and which way round does the guide fit in the upper case?
Eric
Offline kevski
Re: CB350f Prinary Chain Guide
« Reply #1 on: December 28, 2016, 02:36:31 PM »
I have just looked at a video of a strip down and the hole faces rearwards.
« Last Edit: December 28, 2016, 02:56:50 PM by kevski »
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #2 on: December 28, 2016, 06:02:28 PM »
Hi Eric,
As Kevski says, the dimple faces rearwards  towards the gearbox on both guides. I put a piece on my site regarding rebuilding my spare 350/4 engine. It's part 4 in the 350/4 section.
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Offline H2Eric
« Reply #3 on: December 29, 2016, 09:55:39 AM »
Thanks guys. Off into the garage now to change it around, not for long though as it's f-f-freezing c-c-cold in there.
Eric
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #4 on: December 29, 2016, 03:55:55 PM »
It's been 10 deg C all day here in the frozen north of Orkney, might have to remove one or two vests!
Don't forget those different length lower engine bolts when you put it back in the frame,
Ian
1972 Honda CB 350/4
2026 Honda ADV 350
Offline Chris400F
« Reply #5 on: December 29, 2016, 04:15:39 PM »
Parts List is always good if you need to check bolt lengths as it gives all bolt diameters and lengths.
« Reply #6 on: December 29, 2016, 05:00:18 PM »
Eric
I hope you survived the garage Eric, living just down the road from you I can confirm it is brass monkeys out there, got to the balmy heights of +1 today. Bring on Summer !!! ;D ;D ;D
