Author Topic: Brake caliper thread refurb  (Read 2689 times)
« on: December 28, 2016, 09:52:09 PM »
I'm on a roll now! Not a priority now but will be doing a double disc conversion at some point and just found an early K caliper in the shed that has the for and aft brake pipe and nipple set up (as opposed to the inboard brake pipe and nipple on the outside) - this matches the existing one on the other side.
The brake pipe thread is stripped. Two questions:- can the brake nipple and pipe threaded holes be reversed to  accommodate reversing the caliper.
And if so, I read a post not to long ago that a member has a brass insert to replace the thread when damaged but can't find the post now - if so, can they contact me please
Re: Brake caliper thread refurb
« Reply #1 on: December 28, 2016, 10:05:26 PM »
Just found the post ref the repair insert - its Brianj so if anybody can answer the first question, I can contact Brian
« Reply #2 on: December 29, 2016, 01:21:28 PM »
If its a 750 I have to fit the brass insert into a upducer and retap the caliper, Works fine but sticks out a bit, This is because I can only get inserts for the smaller bleed nipple now
« Reply #3 on: December 29, 2016, 06:39:40 PM »
Thanks Brian - I'll be in touch if I can't sort another option - the double disc option hinges on my first question really, i.e. can I reverse the bleed and brake pipe holes to facilitate pipe entry from the left of the caliper (when used as an offside 2nd disc/caliper and viewed from the offside)
« Reply #4 on: December 30, 2016, 05:32:29 PM »
On the 750 caliper (but not the 500/400) there is an insert at the bottom of the pipe hole that can be removed carefully and transferred to the bleeder hole, it has an external "cone" on each end to alter the bleed seat to a pipe seat
« Reply #5 on: December 30, 2016, 07:28:39 PM »
I spotted that Brian - any tips on removal?
« Reply #6 on: December 31, 2016, 01:43:19 PM »
Never done one but the yanks say gently screw a self taper in and work the union out
« Reply #7 on: December 31, 2016, 03:51:19 PM »
My thoughts too - will have a go and feed results back to forum
