Try our re-instated info resource - "Aladdin's Cave" (Main menu)- sorry it's taken so long to fix
A bit defeatist but is it worth shifting?The last knackered one I got out just revealed a very corroded bore.
Not impossible. It's like nailing jelly to the ceiling though. It took me well over an hour. The trick is to make the aforementioned sharpened chisel - like screwdrivers dig in to the metal, prising the circlip out as far as you can, keeping it there while you dig the second one in. Once the clip is free of the groove, it's relatively simple. No, I'm not volunteering to go through that again.
Quote from: mike the bike on January 21, 2017, 11:35:44 PMNot impossible. It's like nailing jelly to the ceiling though. It took me well over an hour. The trick is to make the aforementioned sharpened chisel - like screwdrivers dig in to the metal, prising the circlip out as far as you can, keeping it there while you dig the second one in. Once the clip is free of the groove, it's relatively simple. No, I'm not volunteering to go through that again.Oh go on....see if you can beat your personal best time ...It's a great challengeSent from my iPad using Tapatalk
