Author Topic: Battery resurrection  (Read 5719 times)
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
Re: Battery resurrection
« Reply #15 on: January 18, 2017, 12:30:40 PM »
Not sure that you will recover the battery, may depend on the charger that you are using?
Never used 'optimizers', but I did buy a 2 amp bike charger (image attached) a number of years ago as battery suppliers recommendations.
A definite improvement on the life of my batteries
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Offline El__burro
« Reply #16 on: January 18, 2017, 01:24:33 PM »
What a response..
i will disconnect it right now.
I've read motobatt, are they the ideal?
thanks
el__burro
« Reply #17 on: January 18, 2017, 01:28:20 PM »
Yes they are very good. Glass matt batteries are fuss free with no acid to leak onto your chrome and paint. They can be left without an optimiser or charging for months without any problems. The cranking amps are also far superior to ordinary lead acid.
« Reply #18 on: January 18, 2017, 05:42:36 PM »
I've switched over to mottobat's on two of my bikes now. Very well made and a strong performance. I especially like the dual terminal fixing option and the use of Allen headed terminal fixings instead of the usual dumb semi-captive back nut that always falls out and drops down behind the engine never to be seen again. Another option is an Odyssey battery, fantastic but expensive. I have one fitted on my Jota, it's smaller then the original but has the power to spin the motor fast enough for instant starting. Its lasted 7 years so far, result!
Offline Green1
« Reply #19 on: January 19, 2017, 09:13:54 AM »
Mottobat are the way to go if you own a number of bikes just swap the terminals over and fit to another bike
They have saved me a small fortune in batteries and sprag clutches in the Aprilia
The one in my dads Triumph Trophy 1200 is mounted on its side and about 4 years old now
Mottobat did go through a stage of selling duds but they seem good again now.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline totty
« Reply #20 on: January 19, 2017, 02:13:18 PM »
I've bought three motorbatt and I'd consider one to be a dud, wont start if left a month, but will if switched back to the old varta battery.
