Author Topic: well how about this...  (Read 11095 times)
Offline pae
    • Phil's CB650 pages
« on: February 18, 2007, 04:24:51 PM »
OK, it's a fairing, any idea of the make from the shape of the logo that should be stuck on the front?
regards, Phil
jimshea
Re:well how about this...
« Reply #1 on: February 19, 2007, 10:01:08 AM »
Possibly a Dunstall??
« Reply #2 on: February 19, 2007, 12:36:32 PM »
That's a Rickman \"Type 1\" which was a 1/2 fairing. The size and shape of the badge are the givaway.  Run a Google or eBay search for more pictures to compare.
The pic in my avatar is the \"Type 2\" 3/4 version.
Post edited by: SteveD CB500F, at: 2007/02/19 12:37
Offline pae
« Reply #3 on: February 19, 2007, 12:43:09 PM »
Thanks Steve, I thought the shape was a rickman but was not certain. I'll do an image search, but do you know of (or have) any pictures showing the mounting arrangement for these?
Also, you can see I need a screen - was somewhere in Hampshire mentioned on here a while ago as a possible source?
regards, Phil
« Reply #4 on: February 20, 2007, 08:25:25 AM »
On the 500/550/750s that we had in the 70's, the bracket mounted to the steering head and was clamped via the tank mounting lugs (this meant you had to cut down the tank rubbers). Then two (rather flimsy) brackets from the side to the rear engine mounts. I don't know whether the type 1 had any lower mounts or not. The fairing was \"QD\" ie you could undo two large bolts under the screen and two each side by the engine and lift it off. As the headlamp remained mounted on the fairing frame, you could ride it around naked !!
I recall a screen thread, either here or on sohc4 - I'll have a little poke around.
There is a member of sohc4 in Peterborough with a Yoshi 500/4 with one of these fitted. I'll email him and get him to post some photos.
Offline pae
« Reply #5 on: February 20, 2007, 01:09:38 PM »
Thanks Steve, I had found this link to a picture which shows the headstock clamp on a Rickman, http://www.vx800.net/fairings/tempest7.jpg
...and this is the link I recalled...http://www.honda-sohc.co.uk/index.php?option=com_joomlaboard&Itemid=157&func=view&id=877&catid=1#877
regards, phil
Post edited by: pae, at: 2007/02/20 13:14
« Reply #6 on: February 20, 2007, 03:30:43 PM »
Hmmm. That one has a \"U\" bolt around the headstock. Not the same as our Hondas back then.
number8
Re: well how about this...
« Reply #7 on: July 13, 2007, 10:22:13 PM »
Howdy deffo a rickman
that member in pborough was lil old me
pics
http://hdnumber8.hostaim.com/Dscf0238edit.jpg
http://hdnumber8.hostaim.com/Dscf0240edit.jpg
http://hdnumber8.hostaim.com/Dscf0241edit.jpg
gotta copy and paste the links  as the hosting is a bit poo
if u want some pics of the bracket gimme a shout
hdnumber8@gmail.com
« Reply #8 on: July 14, 2007, 11:05:39 AM »
And you never replied.
I see you have a new email address so I'll let you off (this time)
number8
« Reply #9 on: July 14, 2007, 11:41:14 AM »
yea the hole breakup mean that it all went to shit a bit
moved to webmail , then im not tied to a contract if u get my drift
had to get rid of alot of my bikes , kept hold of the cb as i didnt wanna sell it , but ive gave in and its gotta go ...
bloody wimmen !!!!!!
