Author Topic: Idle air screws (CB350F)  (Read 1990 times)
« on: February 03, 2017, 04:22:40 PM »
Just as a check, what settings have you 350F guys got for your air screws. Standard is 7/8 out but that was back in 72 when there was tons of lead in the petrol. Is anybody running things differently with success. Although it runs, starts and idles good, I Am having a bit of trouble just off idle. If the throttle is opened too quickly the engine dies. Cheers.
« Last Edit: February 03, 2017, 08:28:15 PM by royhall »
Offline kevski
Re: Idle air screws
« Reply #1 on: February 03, 2017, 05:12:13 PM »
Mine are about 1 and 1/4 turns out and i am now using a delkevic pipe it picks up quite nicely with a quick blip of the throttle, if i really go for it though it wants to die i will be trying to improve on that when the weather warms up, i also have mine at around 1300 idle speed, it's always been similar with all the 1970s fours i have owned the only one it was not like it on was a Z thou that had accelerator pumps on the carbs and others that have had CV carbs. maybe a video of the bike running and blipping the throttle may help us to assess it better.
https://youtu.be/K5n9On2vM_I
