Author Topic: C5 ignition and coils, what spark plugs  (Read 2544 times)
Offline Mag1
« on: February 08, 2017, 10:10:04 PM »
I have c5 electric ignition and coils, my wiring is near complete and hopefully have all connected and tested in the next couple of weekends. Then I will start the ignition setup. But I am confused with the spark plug caps, I have ngk iradium plugs fitted, plus I have standard plugs on standby.
The caps that came with the bike are ngk caps, but I don't know what ohms they are or if I buy new caps which ones do I purchase, I have been reading on here and on the other sohc forums but now I am confused which ones I need as I might as well replace what I have as I don't know how old they are. Is it the lower the ohms the better or higher eg 2000, 5000. Confused. Yep I am
Honda CB750K7 1977
Yamaha XS750e 1977
Vespa 100 (being restored)
Re: C5 ignition and coils, what spark plugs
« Reply #1 on: February 09, 2017, 08:21:27 AM »
http://www.motorcycleproject.com/text/plugwiretech.html
This link may help you work though it, has a sub section about Honda SOHC ignitions in a link at base of article.
« Reply #2 on: February 09, 2017, 10:45:07 AM »
  this is a brilliant article ,
thanks for posting
Offline Chris400F
« Reply #3 on: February 09, 2017, 11:28:52 AM »
thanks for posting
It certainly is (the linked SOHC article), need to spend some time reading it more thoroughly.
So what is it about GL1000 Gold Wing coils that made them a popular upgrade?
« Reply #4 on: February 10, 2017, 07:49:02 AM »
They are 9v coils run with a ballast resistor on the wing
Offline Mag1
« Reply #5 on: February 11, 2017, 08:31:17 AM »
Excellent, many thanks. Quite fancy a gold wing, really nice engines with plenty of power. Maybe next time.
Honda CB750K7 1977
Yamaha XS750e 1977
