Author Topic: Which Indicators  (Read 5717 times)
Offline Deano400
Which Indicators
« on: February 10, 2017, 09:04:06 PM »
Hi. Some advice sort. I have two types of indicator on my 1978 400. Can someone advise me on which is original if any? Also the mounting brackets are different. I believe the short one is original. Any help appreciated.
Re: Which Indicators
« Reply #1 on: February 10, 2017, 09:31:45 PM »
Originals are Stanley and the top bracket in your pic looks CB400/4
« Reply #2 on: February 10, 2017, 10:15:10 PM »
Bottom indicator is OEM, top is repro. Bottom rear indicator bracket is CB750/CB500 four, top CB400 ;)
« Reply #3 on: February 10, 2017, 11:12:27 PM »
Bottom indicator
Bottom bracket
« Reply #4 on: February 11, 2017, 11:00:16 AM »
Just been out into the garage to check my own 400, the bottom bracket is correct for a 400/4.
Offline Chris400F
« Reply #5 on: February 11, 2017, 11:44:41 AM »
I'd go with that too.
Just measured a set I have that came from a 400, shaft length is approx. 65mm.
« Reply #6 on: February 11, 2017, 12:03:42 PM »
Seeing that Deano400 has not given the measurements of the stems, all I know is the CB750/CB500 is 25mm and the CB400 is 65mm. Don't know if Honda did a longer stem.
If he has taken the picture on a worktop with 20mm staves, that will give the bottom one as about 25mm.
« Last Edit: February 11, 2017, 12:11:18 PM by Trigger »
Offline Chris400F
« Reply #7 on: February 11, 2017, 01:43:24 PM »
I'm guessing the picture was taken with the parts on something like laminate flooring.
That would fit with the body of the bracket measuring approx. 70mm.
Hopefully Deano will confirm which one seems to fit with the measurements.
Offline Deano400
« Reply #8 on: February 11, 2017, 03:43:57 PM »
Thanks all for taking the time to help me out. Further photo attached showing lengths.
Offline Seabeowner
« Reply #9 on: February 11, 2017, 03:56:54 PM »
Jumping in here, I'm after one or two of the short CB500/750 rear stems and rubber mounts if anyone has any.
No doubt I'll post a desperately seeking in a couple of months as better weather approaches. (Please...)
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline Honda Al
« Reply #10 on: February 11, 2017, 05:59:10 PM »
I might have some. I'll look in the garage tomorrow for you.
Alan
Offline Seabeowner
« Reply #11 on: February 12, 2017, 10:41:12 AM »
Thanks for the replies and for looking.  Am looking at the differences, to turn a 500K0 USA model into as near UK spec as I can.
« Reply #12 on: February 12, 2017, 12:15:06 PM »
For more reliable flashing,  best add a 0V return lead using the screw inside the indicators,  connecting it to the green wires under the seat/headlamp shell.
