Author Topic: WILL THE RIM FIT????  (Read 5326 times)
« on: February 13, 2017, 07:18:45 PM »
Hi Chaps
On my CB550 project, I quite fancy a chunky looking back wheel instead of the standard size of 1.85 x 18. The question is will a 2.15 x 18 CB750 wheel rim have enough clearance in my CB550f swing arm ?
Ta in advance
Julie x
« Last Edit: February 13, 2017, 07:38:19 PM by Nurse Julie »
Offline Chris400F
Re: WILL THE RIM FIT????
« Reply #1 on: February 13, 2017, 07:29:14 PM »
Thought I'd seen a similar query recently.
Does this thread help Julie? http://www.sohc.co.uk/index.php/topic,11927.msg91289.html#msg91289
Offline kevski
« Reply #2 on: February 13, 2017, 07:35:20 PM »
When i wanted a wider wheel on mine the swing arm would only allow for a 20mm wider tyre that allowed me about 5mm gap between the swing arm and tyre , you can increase the tyre size and keep the standard rim, it's only a small increase so won't affect the handling at normal speeds.
« Reply #3 on: February 13, 2017, 07:39:03 PM »
Are you talking about a CB550F swing arm?
« Reply #4 on: February 13, 2017, 08:15:36 PM »
Julie !!
  the last thing a slim lady like you needs a chunky rear end !!!
« Reply #5 on: February 13, 2017, 08:20:15 PM »
 ;D ;D ;D I find not eating too many burgers helps John
« Reply #6 on: February 13, 2017, 08:41:52 PM »
  agrees,I hardly eat enough to keep a bird alive !!
Offline Menno
  • www.tanklackieren.de
« Reply #7 on: February 13, 2017, 08:58:54 PM »
Someone is working on the same project in Germany:
Ich habe einen Felgenring der 750Four 2.15x18 hinten und wollte den auf meiner 500FourK1 hinten einsetzen die einen vergammelten Originalring 1.85x18 und verrostete Speichen hat. Das scheint ja zu passen wenn ich das hier so lese.
I would say, if it fits in Germany.... ;)
« Reply #8 on: February 13, 2017, 09:08:14 PM »
Thanks for all the replies chaps. Menno, Trigger has just translated that for me. EVERYBODY IS TALKING ABOUT A CB750 / CB500/4 SWINGING ARM. I AM ASKING ABOUT A CB550 F SWING ARM  ::) ::) ::)
Offline kevski
« Reply #9 on: February 13, 2017, 09:42:08 PM »
Yes 550.
« Reply #10 on: February 13, 2017, 09:49:47 PM »
Thanks but is yours a K or F as I know they have different shaped swinging arms
« Reply #11 on: February 14, 2017, 08:43:00 AM »
Thanks Ken. I wii have a rummage in Trigs workshop to see what I can find. I will have to wait till next week to try it out as my frame and swing arm and all the other bits went to the powder coaters yesterday.
Offline kevski
« Reply #12 on: February 14, 2017, 09:33:43 AM »
It was actually a 500k3 identical to 550k3 and I got a 4.25 tyre in there.
Offline Menno
« Reply #13 on: February 15, 2017, 09:30:59 AM »
Are there differences in the cb500 k swingarm and the cb 550 f swingarm?
« Reply #14 on: February 15, 2017, 09:49:44 AM »
Different animal all together  ;)
