Author Topic: CB500 Front brake hose  (Read 5750 times)
Offline sgd37
« on: February 24, 2017, 06:32:42 AM »
Hi gents,
Looking to replace my front brake hoses. Does anyone know if the 750 brake hoses would fit on a 500.
Also would it be possible to replace rocker shafts which come as one per rocker for the later models 550 with one for two rockers, or should I lathe my own.
cheers
Re: CB500 Front brake hose
« Reply #1 on: February 24, 2017, 07:35:08 AM »
Yes and Yes but, the hose comes in different lengths for hi or low bars
« Reply #2 on: February 24, 2017, 09:06:20 AM »
There are three different rocker spindles
(1) the eight loose
(2) the four loose
(3) the four locked as on late 550's
Not 100% sure but I don't think you can fit the locked ones to any early cover (1) & (2) should interchange
Offline sgd37
« Reply #3 on: February 24, 2017, 04:51:38 PM »
Great good to know. Guess I'll measure my old hose for the length.
As for the spindle seems it's possible to fit the locked type after some modifications. Found this on youtube
https://www.youtube.com/watch?v=MDIkDb_HhKw
So would any of you two gents have four candles...I mean four lockable spindles
Offline sgd37
« Reply #4 on: February 24, 2017, 09:13:16 PM »
maybe i could just drill a hole for the screw. Shouldn't affect the structural integrity too much should it? the screw would probably give out before the spindle if something happens.
How much would you want for four of them? Saw your edit
If I were to make my own what material would I use?
« Last Edit: February 24, 2017, 09:17:13 PM by sgd37 »
« Reply #5 on: February 25, 2017, 01:48:20 PM »
Part number is 14451-323-020 if you can find old stock anywhere
Offline sgd37
« Reply #6 on: February 26, 2017, 01:10:12 PM »
at 20 quid +VAT a pop I'll attempt making my own first. Some stainless steel rod should do
