Author Topic: Compression numbers.  (Read 7773 times)
Re: Compression numbers.
« Reply #15 on: April 09, 2017, 05:44:42 PM »
Have you done anything with the bores, new rings, X hatched ?
Offline onethumb
« Reply #16 on: April 09, 2017, 07:06:42 PM »
Hi trigger. No the bores were really good. But I've just took it all apart and you can see that the new gasket has not sealed around 3-2-1. Has any one else had issues with the gasket kit from DS. Any recommendations for a new head gasket?
« Reply #17 on: April 09, 2017, 07:28:05 PM »
You haven't fitted it back to front have you? (Seen it done!)
Offline onethumb
« Reply #18 on: April 09, 2017, 07:30:28 PM »
Nope. On the f2 you can't. Luckily for me.
Offline yozzer74
« Reply #19 on: April 10, 2017, 05:42:50 PM »
The 4 notch pins that the rubber seals go round are  they sitting lower than the gasket ?? Just a thought .
Offline yozzer74
« Reply #20 on: April 10, 2017, 05:45:05 PM »
And David silvers has got 2 genuine head gaskets in stock for the F2
Offline onethumb
« Reply #21 on: April 10, 2017, 06:17:53 PM »
Hi Yozzer, I had them seated level with the top of the pins then pushed in to the hole till they bottomed out. Does that sound right? Those rubbers are not the best design I've ever seen.
Offline onethumb
« Reply #22 on: April 10, 2017, 06:19:00 PM »
Has he. I'm on the net.
Thanks dude.
Offline onethumb
« Reply #23 on: April 10, 2017, 07:16:27 PM »
Yozzer have you got a part number for the gasket as I can't find them on the site? Thanks
Offline yozzer74
« Reply #24 on: April 10, 2017, 07:39:25 PM »
12251410000   Part number          I ment are then pins flush with barreles and not raised above them
Offline onethumb
« Reply #25 on: April 10, 2017, 07:41:54 PM »
Thanks.
The pins are flush the rubbers sit high though.
Offline yozzer74
« Reply #26 on: April 10, 2017, 07:48:22 PM »
http://forums.sohc4.net/index.php/topic,107040.msg1197785.html#msg1197785 It just a thought as I had seen it on this thread before . Be interesting to see what lads on here think to this thread how to rebuild top end
Offline onethumb
« Reply #27 on: April 10, 2017, 08:43:17 PM »
Thanks dude just read it. I'll be doing some checking tomorrow.
Has anyone else left the 8 rubber seals/washers out.
« Reply #28 on: April 10, 2017, 09:00:53 PM »
If you're talking about the little rubber sleeves that fit round the dowels, F2 engines should only use 4, seems like your gasket kit was generic aftermarket, as F1's and K7's use all 8.
Offline onethumb
« Reply #29 on: April 10, 2017, 09:20:09 PM »
Yep hairygit I did use 8. So it's just the 4 that go on the pins that I need then? When I stripped it the other build had used 8. Reading the link that Yozzer pinned I'm thinking of ditching all 4/8.
Any thoughts. .?
