Author Topic: Rebore costs  (Read 6899 times)
Offline llessur
  • Honda 400/4
Rebore costs
« on: March 01, 2017, 10:40:53 AM »
I have just had a quote fore boring my 400 barrels to 54.5mm for a big bore conversion. They said £40 per cylinder.
I just wanted to check this was reasonable as I have not done this before. What do you think?
Offline kevski
Re: Rebore costs
« Reply #1 on: March 01, 2017, 12:33:21 PM »
Nothing wrong with that.
Offline Zunspec
Re: Rebore costs
« Reply #2 on: March 01, 2017, 01:53:49 PM »
It is in the ball park.  Steve at Pistonbroke in Bristol charges approx £30/barrel so may be a bit cheaper.  The handy thing is if you make an appointment he will do the job while you wait. He's been doing it for 40+ years so he knows what he doing.
Cheers  Geoff
Re: Rebore costs
« Reply #3 on: March 01, 2017, 03:15:22 PM »
£40 is cheap, seeing it is multiple cuts and a few times they have to re-set the boring bar.
Offline llessur
  • Honda 400/4
Re: Rebore costs
« Reply #4 on: March 02, 2017, 09:13:45 PM »
Thanks everyone. I took them in this morning. My only concern is that there is not going to be a great deal of wall thickness left at the bottom of each sleeve and the loss of any usable chamfer may mean a faff with the rings. Just an idea but is it possible to sick two pistons in the barrel first then just fit the gudgeon pins rather than attempting all four piston whilst lowering the cylinders ?
Re: Rebore costs
« Reply #5 on: March 03, 2017, 07:48:29 AM »
Doesn't sound feasible.   Everything's going to move out of alignment while you're trying to something fiddly.  I make ring compressers from drinks cans, held in place with cable ties.
Offline Chris400F
Re: Rebore costs
« Reply #6 on: March 03, 2017, 08:51:08 AM »
I tend to agree with Mike. It may be a faff with the rings, but I think it would be a bigger faff with the gudgeon pin circlips when the pistons are in the bores
Offline Rozabikes Tim
Re: Rebore costs
« Reply #7 on: March 03, 2017, 08:56:56 AM »
What about the yogurt pots and double sided sticky tape Val?
Re: Rebore costs
« Reply #8 on: March 03, 2017, 08:59:24 AM »
If you're happy with the Blue Peter method, go for it. ;D ;D ;D
Offline llessur
  • Honda 400/4
Re: Rebore costs
« Reply #9 on: March 03, 2017, 09:15:52 AM »
Thank you for the responses. I will avoid the copydex, coathangers and sticky backed paper ( nice to know we are of a similar generation ) but I do like the Coke can idea. I will give it a try.
Offline Tomb
Re: Rebore costs
« Reply #10 on: March 03, 2017, 09:16:59 AM »
Doing drag racing means we do this job several times a year on two engines, I have polished the chamfers and polished a small radius between the bore and chamfer. Using engine oil and fitting the block over 2 + 3 pistons first the block almost falls on, then rotate the crank slightly to lift 1 + 4 pistons and drop the block onto them, the rings slide in easily. Best done with two people, one each side of the engine.
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
Offline kevski
Re: Rebore costs
« Reply #11 on: March 03, 2017, 10:07:07 AM »
Just the ticket, i have never used coke cans, plastic bottles, bits of drain pipe, or even ring clamps, and have never broken a a single ring, you just take care and do as tomb says .
Offline Underdog1
Re: Rebore costs
« Reply #12 on: March 03, 2017, 10:50:21 AM »
That bloke on hackaweek did something sort of similar by fitting pistons and conrods in that barrels and then fitting them to the upper crank case, looks an awkward way to do it
https://youtu.be/y-CsqUiatKk
Are you not able to add a small amount of new chamfer to the bottom of the sleeves?
