Author Topic: K0 Master cylinder problem  (Read 4561 times)
Offline RGP750
« on: March 02, 2017, 06:58:06 PM »
Bike is almost finished and i have filled the master cylinder and have a problem.
The body was cleaned and a new plunger/seal kit fitted.
The brake fluid won't pump down the pipes.
I have the nipple removed and left the cylinder filled last night with the lever pulled in (i assume this
will leave the access out open).
No fluid has left the cylinder,pumping the lever doesn't make it move either.
I took the lever off and the plunger mover freely by pushing with a brass rod.
Any ideas welcome please.
Rich
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Re: K0 Master cylinder problem
« Reply #1 on: March 02, 2017, 07:07:18 PM »
Prime the master cylinder  ;)
« Reply #2 on: March 02, 2017, 07:07:59 PM »
Hi Rich
I had a similar problems a few years ago when I built my K2 - it turned out to be one off the tiny holes blocked. Cleared it with a 1mm drill bit and bleed straight away
Offline RGP750
« Reply #3 on: March 02, 2017, 07:13:59 PM »
I have Trigg.
I'll take a look at that Phil Ta.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Offline RGP750
« Reply #4 on: March 02, 2017, 08:23:13 PM »
Me again
Taken master cylinder off, washed out and yes Phil hole looks blocked, i used a
jewelers eye glass and the hole is minute.
One strand of copper harness wire won't clear it.
Is it ok to open the hole up? I probably have a .5mm drill  at work
but that is larger than what is there.
Rich
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
« Reply #5 on: March 02, 2017, 08:34:10 PM »
Is that the one Trig stripped down for you 2 years ago Rich?. If it is, it's taken you long enough to realise the hole is blocked  ;D ;D Mind you, at least you haven't lost it which is a major result!!! Xxx
Offline RGP750
« Reply #6 on: March 02, 2017, 08:47:14 PM »
Re building is a learning curve for the first major re build i'm sure you know Julie.
Did Trig leave it blocked to see if i noticed then ????? ;) ;D ;D ;D
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
« Reply #7 on: March 02, 2017, 08:51:12 PM »
Hehe, yes, I'm sure I saw him plug the hole just in case you lost something down it  ;D ;D I wouldn't know where to start with a master cylinder rebuild Rich, luckily I have never had to do more than top them up with oil, luck I suppose.
« Reply #8 on: March 03, 2017, 06:54:23 AM »
I can remember advising you when I stripped both the master cylinders to check the holes  ;D
« Reply #9 on: March 03, 2017, 05:00:22 PM »
I used a 1mm and everything has been fine with braking after about 800 miles. Like you said Rich, I couldn't shift the crud without drilling it out - I think I used a small adjustable collet tap wrench (with tin foil wrapped around the drill bit to get the grip) then turned it by hand. But using a small variable speed drill should be ok in my opinion
Sent from my MotoG3 using Tapatalk
« Reply #10 on: March 03, 2017, 07:05:43 PM »
I use  two strands of copper multistrand flex twisted together
Offline RGP750
« Reply #11 on: March 03, 2017, 07:17:55 PM »
Thanks all.
I tried the copper wire trick, no luck, pulled a bristle out of a wire brush, still no luck .
I found a .6mm drill and i have a pin chuck so going to strip out the new plunger etc, When i can get the
blooming circlip out.
I have bought a new repair kit. Drill out the hole and have another go.
Report back later.
1973 CB175
1972 CB175
1969 750 K0
Offline Niko
« Reply #12 on: March 03, 2017, 08:30:23 PM »
I'm just having the same problem. Fitted the rebuild kit last night.
Can someone tell me what the two holes in the master cylinder reservoir do please. I can see the piston move through one....but not the other.
Offline RGP750
« Reply #13 on: March 03, 2017, 09:00:29 PM »
The hole nearest the lever is quite large but the one nearest the banjo is VERY small you will need a magnifying glass to see it well.
This hole seems prone to blocking if it is an old master cylinder and corroded.
I propose to drill mine out this weekend.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Offline Niko
« Reply #14 on: March 03, 2017, 09:42:12 PM »
Cheers....I boiled mine when I disassembled it....so hopefully it will poke thru?
