Author Topic: K0 Master cylinder problem  (Read 4730 times)
Offline Tomb
Re: K0 Master cylinder problem
« Reply #15 on: March 04, 2017, 07:59:53 AM »
Can someone tell me what the two holes in the master cylinder reservoir do please.
The big hole is to let fluid into the cylinder to be pumped, the small hole is to allow a small amount of fluid back into the res' when you release the lever so the brake piston can back off a little, if its blocked you will have drag. Commonly known as a "spooge hole"
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
Offline RGP750
« Reply #16 on: March 04, 2017, 10:16:25 AM »
Cylinder stripped. "spoogle" hole drilled out ,new Plunger etc fitted.
and bled.
Works a treat.
Thanks again to this forum and it's members.
I have the bike booked in at Ardingly show 2 April.
Never put a bike into a show before .
Anyone on here going?
Cheers again Rich
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
« Reply #17 on: March 04, 2017, 01:28:44 PM »
and bled.
Works a treat.
Cheers again Rich
I have scrutinised your entry form as head judge, and I look forwards to see the completed bike ;)
Offline RGP750
« Reply #18 on: March 04, 2017, 06:33:26 PM »
I will
Put up photos as well Trigg ,i welcome your scrutiny and comments ;)
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
« Reply #19 on: March 04, 2017, 07:36:50 PM »
I will
I will be keeping my eye out for incorrect fitted springs  ;D ;D ;D
Offline RGP750
« Reply #20 on: March 04, 2017, 08:21:58 PM »
If that's all you find i will be happy :D :D
(and you won't find that) ;)
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Offline Niko
« Reply #21 on: March 05, 2017, 05:14:54 PM »
Thank you
