Author Topic: Spacer on rear axle sprocket carrier... help please.  (Read 1638 times)
Offline neilg
« on: March 03, 2017, 07:22:40 PM »
I'm building a bit of a bitsa to use up my stock of old parts. The plan is to use a rear wheel from a 750 K7. However the spacer on the bearing for the sprocket carrier (part no 42605-393-000) is missing. I have one from an F1 (part no 42605-300-000). I am assuming they will be different due to the different numbers. If any one is able to measure the diameter and length of the thick section of a K7 spacer could they let me know so I might be able to machine the one I have to fit. So if you happen to have one to hand please help me out it would be a great help.
Offline neilg
Re: Spacer on rear axle sprocket carrier... help please.
« Reply #1 on: March 06, 2017, 12:45:13 PM »
Managed to source a reproduction spacer on E bay all the way from Germany.
For info for anyone interested the parts are different between F1 and K7. Though interchangable with various other models. eg the K7 spacer is used on a variety of others including CBX and some 80's Hondas.
