Author Topic: 750f REAR MASTER CYLINDER  (Read 2741 times)
Offline Moorey
« on: March 19, 2017, 07:51:15 PM »
Help needed, I can't find a rear master cylinder seal kit for a USA 1976 CB750f I assume all F1s the same. DSS and CMS no stock. Its just starting to show wet. If it gets to the dripping stage will brake fluid do any damage to the silencer. I know it does paintwork no favours.
Cheers Chris
Offline Green1
Re: 750f REAR MASTER CYLINDER
« Reply #1 on: March 19, 2017, 07:53:26 PM »
Brake fluid will strip chrome. and paint with ease.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Moorey
« Reply #2 on: March 19, 2017, 09:15:48 PM »
Does anyone know if the actual seals in the front master cylinder are the same as the rear master cylinder.
Offline haynes66
« Reply #3 on: March 20, 2017, 07:40:23 AM »
they are on the F2 but i dont know if the F1 has the same calipers
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
« Reply #4 on: March 20, 2017, 07:59:35 AM »
Use Motogrid to get the correct part number then put that into thier parts search and it will tell you all the bikes that it fits, also find a local dealer with a Hi Level account as they have pages n pages of brake seal kits
Offline Moorey
« Reply #6 on: March 20, 2017, 11:11:15 AM »
Not available with Motogrid but thanks anyway. I have read that early GL 1000 seal kits fit  with little modification to the pushrod. I've ordered one so we will see.
Offline Moorey
« Reply #7 on: March 20, 2017, 11:14:17 AM »
Thanks Spitfire I read the same thing last night and ordered one.  :)
Offline Moorey
« Reply #8 on: March 20, 2017, 05:20:02 PM »
I have just pulled the rear master cylinder in bits and the original front master cylinder and doing some measuring. The 2 piston seals in both front and rear master cylinders are the same. Could be a bit of useful info for someone.  Both cylinder bores are 14mm and pistons 13.8mm
« Reply #9 on: March 20, 2017, 05:28:32 PM »
That's handy info, I'm sure that somewhere on here there is a section that lists interchangeability, might be useful there.
Offline Moorey
« Reply #10 on: March 22, 2017, 06:56:05 PM »
The GL1000 rear master seal kit 43510-371-305 came this morning. The only thing I have had to do is cut 6mm off the threaded pushrod. It works fine. :)
« Reply #11 on: March 22, 2017, 07:00:50 PM »
That's good news for us F1 owners, thanks for posting.
