Author Topic: stator coil testing  (Read 2483 times)
Offline billdn
stator coil testing
« on: March 21, 2017, 07:46:56 PM »
electrics is not my thing, so I've been following Mr Haynes/Clymer. i tested the three yellow wires as it says but the minimum value should be 0.65 ish so if i'm getting more than that averaging 1.0 -1.5 am i OK or is the coil kaput?
Re: stator coil testing
« Reply #1 on: March 21, 2017, 08:36:05 PM »
Depends how accurate your ohm meter is.  It's difficult to measure low resistances accurately with a bog standard meter.   Your readings sound OK, it's not like they're open circuit or anything.
Offline billdn
« Reply #2 on: March 23, 2017, 06:31:18 PM »
Thanks Mike. I'll invest in a lower range multimeter I think.
« Reply #3 on: March 23, 2017, 06:50:45 PM »
It's more helpful to test the ac output of the coils or, better still, check the charging current from the rectifier to the battery.   An ideal tool for testing current is a clamp meter.  Failing that,  checking the dc voltage when the engine is running.
