Author Topic: CB400/4 Supersport  (Read 2111 times)
Offline Integra99
CB400/4 Supersport
« on: March 23, 2017, 04:26:32 PM »
Hi I'm new to the forum and have a CB400/4 SS
It had an oil leak on the rubber seal around the cam cover. I'm not used to this type of cover and I changed the seal and bolted the cover straight back on. I now realise I should have perhaps loosened off the valves, I took the inspection covers off as cleaned the cover but left the valves and simply bolted up the cover to spec.
Before I start her up could I have damaged them? I have kicked over by hand and seems ok but wanted to check as this looks like a site that would know,
Re: CB400/4 Supersport
« Reply #1 on: March 23, 2017, 05:26:22 PM »
It's always worth rechecking the tappet clearances,  it's unlikely any damage would have been caused though.
Offline Integra99
« Reply #2 on: March 23, 2017, 05:36:11 PM »
Yes I thought it should be ok and then read the manual.. and noted to slacken first. I'll check the tolerances many thanks!
