Author Topic: cb750k Motobat battery  (Read 2052 times)
« on: April 15, 2017, 01:20:08 PM »
I'm thinking of getting a Motobat battery for my K2 - for all the reasons articulated by forum members - and looking at the pictures on ebay, the battery posts appear to bolt through vertical post (ie they don't bolt down from the top) - which is 90 degrees out from standard fitting.
Is this a generic picture and the actual battery post is as per the standard 750 battery or would I need to modify battery lead to twist it through 90 degrees?
I'm sure that there must be forum members who use this battery who can advise
Re: cb750k Motobat battery
« Reply #1 on: April 15, 2017, 03:59:37 PM »
Phil. I have had 3 Motobatts recently for different bikes and they all had posts that bolt either way. One of them went onto a 750, so you should be good to go.
Offline Mag1
« Reply #2 on: April 15, 2017, 04:52:01 PM »
"the battery posts appear to bolt through vertical post (ie they don't bolt down from the top)"
yes they do, the battery comes with screws and fixing terminals, so you can have your terminals either on top or from the side or both sides. Can confirm excellent battery and worth investing in if your after a new one.
Honda CB750K7 1977
Yamaha XS750e 1977
Vespa 100 (being restored)
Offline RGP750
« Reply #3 on: April 15, 2017, 05:48:24 PM »
Just put one on my K0  Perfect.
As said fit both ways
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline MarkCR750
« Reply #4 on: April 15, 2017, 06:17:18 PM »
Had one on my CR lying on its side for 2 years, holds its charge perfectly, had one on my xjr1300 for 3 years until I sold the bike, never needed supplementary charging, best batteries I've ever used, roughly the same weight as a lead acid, they have 4 terminals, you can even connect them diagonally if needs be.
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Offline Green1
« Reply #5 on: April 15, 2017, 06:21:38 PM »
As above I have one fitted on its side in a Triumph Trophy starts first time every time even after standing for months.
I have them in all my bikes.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline flatfour
« Reply #6 on: April 15, 2017, 08:01:58 PM »
I fitted one of these to my CB750 K2 around two years ago - faultless to date and with the connectors supplied, the terminals fit as per the original flooded acid battery.
« Reply #7 on: April 16, 2017, 12:13:30 AM »
Thanks  guys - I'll order one
Sent from my MotoG3 using Tapatalk
