Author Topic: Clutch drag?  (Read 6073 times)
Offline Niko
Clutch drag?
« on: April 16, 2017, 06:18:52 PM »
Hi
Now that my bikes running I have another puzzle.
No chain fitted yet.
Pull in the clutch and try the kickstart.....no resistance...clutch engaged.
Start the bike in neutral.....front sprocket stationary.
Drop it into first ....sprocket turns...i.e. Drive.
Pull in the clutch.....and the sprocket still turns with some force.
Is that normal, will the drag of the chain counteract it.?
Re: Clutch drag?
« Reply #1 on: April 16, 2017, 07:21:50 PM »
wait till you fit the chain,
 then see what happens,
Offline Niko
Re: Clutch drag?
« Reply #2 on: April 16, 2017, 07:23:57 PM »
Just hope it doesn't drag me around the garage....
Re: Clutch drag?
« Reply #3 on: April 16, 2017, 07:26:50 PM »
  run it on the center stand,and have the rear wheel in the air,use the rear brake to stop the wheel with the clutch pulled in
Re: Clutch drag?
« Reply #4 on: April 16, 2017, 11:11:40 PM »
Kickstart don't work with clutch lever pulled 'cos it's a secondary kick
Offline Niko
Re: Clutch drag?
« Reply #5 on: April 17, 2017, 09:14:33 AM »
Cheers...what does secondary kick mean
Sent from my SM-G935F using Tapatalk
Offline Niko
Re: Clutch drag?
« Reply #6 on: April 17, 2017, 09:15:34 AM »
I chopped the centre stand off ...lol
Re: Clutch drag?
« Reply #7 on: April 17, 2017, 09:51:50 AM »
Secondary kick means via the clutch, primary kick is direct to crank (ish)
Re: Clutch drag?
« Reply #8 on: April 17, 2017, 10:03:42 AM »
A paddock stand will make your life easier. There's lot's you can do with the bike upright. And running.
Offline Niko
Re: Clutch drag?
« Reply #9 on: April 17, 2017, 12:10:25 PM »
Will sort something....cheers
Offline Niko
Re: Clutch drag?
« Reply #10 on: April 17, 2017, 04:54:21 PM »
It works just fine with the chain on....cheers
Offline Niko
Re: Clutch drag?
« Reply #11 on: April 18, 2017, 12:32:10 PM »
Gotcha...cheers
