Author Topic: Oil pump O rings  (Read 6864 times)
Oil pump O rings
« on: April 19, 2017, 07:51:36 PM »
Does anyone know the thickness of the O ring that is located behind the plate with the 4 bolts on the oil pump. It is about 27mm, but I can not work out the thickness of the old, flat, brittle one.
Re: Oil pump O rings
« Reply #1 on: April 19, 2017, 08:05:50 PM »
I just measured one that's gone oval; 1.45 x 2.32, so it's probably 2mm
« Reply #2 on: April 19, 2017, 08:08:10 PM »
Are you getting 27mm ID Mike ?
« Reply #3 on: April 19, 2017, 08:19:40 PM »
Looks about that.  Don't make me get off my arse for the caliper.
« Reply #4 on: April 19, 2017, 08:27:15 PM »
Get off your arse, I need accurate measurements  :-* :-* :-* :-*
« Reply #5 on: April 19, 2017, 08:31:40 PM »
Wait till I finish this game of crib
« Reply #6 on: April 19, 2017, 08:39:50 PM »
Crib.........are you joking?
« Reply #7 on: April 19, 2017, 08:53:52 PM »
No.  It's a game for grown ups so go back to your game of snap.
I measured the O ring best I can and it's 30mm
« Reply #8 on: April 19, 2017, 08:55:26 PM »
ID ?
« Reply #9 on: April 19, 2017, 09:11:21 PM »
That was the OD.  ID is obviously OD - 2t
« Reply #10 on: April 19, 2017, 09:17:52 PM »
Ok Mike, thanks for that, I owe you anoooooother pint. Trying to stop Hettie leaking like the Torre Canyon. She reminds me of most of my old Triumph's and BSA's at the moment  :'( :'( :'(
« Reply #11 on: April 19, 2017, 09:20:31 PM »
What's up with the O ring, Gone all hard and cracked up has it?
« Reply #12 on: April 19, 2017, 09:22:30 PM »
Yep, they all had, so having a complete rebuild
« Reply #13 on: April 19, 2017, 09:34:50 PM »
Annoyingly,  the gasket set doesn't include that 30mm O ring, the big 60mm (ish) oil pump O ring or the oil filter O ring.
« Reply #14 on: April 19, 2017, 09:43:49 PM »
Yes, luckily I found all of the other 7 O rings I needed to overhaul the pump at home, it was just that one I couldn't quite work the size out.
