CB750
Rear wheel Ovalised?
Topic: Rear wheel Ovalised? (Read 3399 times)
El__burro
SOHC Expert
May 03, 2017, 04:27:12 PM »
Good day...
Issue is felt mainly when rear brake is applied.
I remember cleaning the hub and brshoes.
Anyone with opinions about this.
el__burro
Sent from my SM-G935F using Tapatalk
Last Edit: August 01, 2018, 12:01:32 AM by El__burro
hairygit
Re: Rear wheel Ovalised?
May 03, 2017, 04:44:48 PM »
Brake drum distorted or cracked. Will require skimming in a large lathe if distorted, or replacing if cracked.
El__burro
SOHC Expert
May 03, 2017, 06:54:07 PM »
So not the wheel, the drum?
Is $kimming cheaper than a new drum..?
Any skimmer in London?
What a blow!
el__burro
Last Edit: May 03, 2017, 07:08:27 PM by El__burro
matthewmosse
May 03, 2017, 07:43:20 PM »
There is a guy in Huddersfild who is at least both cheap and very highly reccomended by all accounts. Look over in the cb550 section as his details have just been posted up there.
El__burro
SOHC Expert
May 03, 2017, 10:58:04 PM »
..thanks, Huddersfield looks a bit far from London, I'll have to send him the rear tyre?
That would add a lot to the final cost.
el__burro
El__burro
SOHC Expert
May 06, 2017, 04:57:38 PM »
After giving it a good clean, it was slightly better.
thanks
Last Edit: August 01, 2018, 12:02:27 AM by El__burro
hairygit
May 06, 2017, 08:02:04 PM »
Hate to put a damper on things, but there is NO WAY on this earth I would ride that having seen those cracks! I'd be on the lookout for a good used hub or wheel, or getting a new liner fitted before riding it again. (Sorry
kevski
May 06, 2017, 08:19:46 PM »
Now you have seen it, that makes it a liability, if an MOT tester see that now they are duty bound to declare it unfit for the road, you have also now published it a public domain, if you continue to use it in that state you become a liability.
May 06, 2017, 11:55:44 PM »
There is no way that that will skim, its either a different wheel or a reline. Doubt you will find any one in London with a big enough lathe to do the assembled wheel, I have visited Paul in Huddersfield and he does not need the work as a business but does it "Because he can"
Don't forget when you signed up for your insurance you say you will keep it in good repair and roadworthy, sorry that don't fit in either category no matter what the MOT says
El__burro
SOHC Expert
May 07, 2017, 02:52:56 AM »
Thanks, i was happy to pass the MOT so I can get the bike registration complete. I am quite worried about it all, i could barely feel the problem.
el__burro
Last Edit: August 01, 2018, 12:02:58 AM by El__burro
hairygit
Reply #10 on:
May 07, 2017, 07:07:50 AM »
They would remove the old drum lining, (the iron bit the brake shoes contact which is cracked) and force fit or shrink fit a replacement, then skim it to new spec. The easiest thing would be to find a decent used wheel and fit that to get on the road, then get the damaged one relined as a spare.
MarkCR750
Professional half wit and member
Reply #11 on:
May 07, 2017, 03:21:59 PM »
Try D&K breakers for a replacement wheel, or eBay maybe.
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
CB750
