Author Topic: Main jet O rings  (Read 4125 times)
Main jet O rings
« on: May 09, 2017, 08:19:43 AM »
Hi all,
               Anyone know the size of the O ring on the main jet for the 400/4
Cheers,
Offline andut
  • CB400F, CB400F Cafe & NC30
Re: Main jet O rings
« Reply #1 on: May 09, 2017, 08:43:30 AM »
Paul,
I found a measurement of 3.5mm ID and 1.2mm X section from an online search, butg have never checked it !
Andy
« Reply #2 on: May 09, 2017, 04:27:00 PM »
original part no 16177-551-004  4.2x1.1mm
Offline andut
« Reply #3 on: May 09, 2017, 06:23:50 PM »
Part number description #@%$'s a year old random Google search !
« Reply #4 on: May 09, 2017, 08:48:13 PM »
Found this on the SOHC/4 owners club.
CARB O-RING SIZES: CB350, CB400, CB500, CB550
When rebuilding carbs on the old Honda fours with press-in main jets, you will often find that all the metal parts are fine after a good cleaning, and all that you really need to buy are new O-rings. Honda doesn’t sell the individual O-rings separately….
instead you have to buy a complete carb kit at $10 to $15 per carb. I found an industrial O-ring supplier who was willing to do small-volume counter sales, and was able to get new O-rings at about 50 cents per carb. Sizes are:
Main Jet: 1.2mm cross-section x 3.5 mm ID
Float Seat: 1.5 mm cross-section x 5 mm ID
Float Bowl Drain Screw: AS568-009 (7/32″ ID x 11/32″ OD)
« Reply #5 on: May 10, 2017, 07:03:33 AM »
The sizes and separate part number i quoted are from a very early parts book where everything is seperate
« Reply #6 on: May 10, 2017, 12:29:23 PM »
Thanks Brian.
