Author Topic: Honda CB 400 four bearing codes  (Read 3246 times)
Offline eem46
« on: May 09, 2017, 11:12:33 AM »
Dear All,
I know this subject passes a lot on the forum, but this is my first Honda CB 400 Four engine so I would like to double check the bearing info.
My crankcase stamps outside are BBBBB
My crank paint says: A1 A1 B1 B1 2
My conrods paint says: 1 2(bit blurry, see pic) 3 3
So my cranks bearing codes are: B1 B1 B1 B1 B2, so that is Green, Green, Green, Green and ? (Please advise color shell B2)
Conrods will be: A1 A2 B3 B3, so that is ? Yellow ? ? Please advise color shell A1 and B3
Thanks a lot.
Kind regards,
Emiel
Offline eem46
Re: Honda CB 400 four bearing codes
« Reply #1 on: May 10, 2017, 07:42:39 AM »
Thank Oddjob.
So buy the stuff and plug and play.... so no double check with Plastigauge?
Kind regards,
Emiel
Offline eem46
« Reply #2 on: May 11, 2017, 07:54:44 AM »
Thanks Oddjob!
Do you also agree that the number in the picture on the conrod is a 2?
Kind regards,
Emiel
Offline steven400/4
« Reply #3 on: May 11, 2017, 07:16:03 PM »
spray the numbers with carb cleaner it will stand out till the cleaner runs off it always works for me
cb400f2 x7
honda ss 50
gsx 1400
