Author Topic: Chain gaurd  (Read 4812 times)
Offline Woodside
Chain gaurd
« on: May 18, 2017, 07:54:19 PM »
Hi
cam anyone confirm this is a 400 chain guard..
Looks like one to me.
Offline Woodside
Re: Chain gaurd
« Reply #1 on: May 18, 2017, 08:01:28 PM »
Probably should've put this in what is it group....could it be a 550
Re: Chain gaurd
« Reply #2 on: May 18, 2017, 08:40:56 PM »
Looks like a CB 400 but could also be a CB550, difficult to tell from photo
Offline Woodside
Re: Chain gaurd
« Reply #3 on: May 18, 2017, 08:46:12 PM »
I know they look real similar....anyone know any definate difference between them...i guess it's down to measurements..?
Re: Chain gaurd
« Reply #4 on: May 18, 2017, 08:50:19 PM »
I can measure the 400 tomorrow morning Jason if you don't get a definite answer this evening
Offline Woodside
Re: Chain gaurd
« Reply #5 on: May 18, 2017, 08:57:28 PM »
Cheers Julie
No panic it's just one i have loitering... It came attached to a 500 but I know it's definitely not a 500 one
Offline kent400
Re: Chain gaurd
« Reply #6 on: May 19, 2017, 08:09:26 AM »
This is a genuine 400f one, it has a raised portion just below just below where the it slips under the shock absorber mounting. The raised portion has a small hole in it and the purpose of that is to hold the chain when removing the wheel by sticking a pin though it. At least that's what I thought it was for!
Offline Seabeowner
Re: Chain gaurd
« Reply #7 on: May 19, 2017, 10:00:52 AM »
Jason, Yours looks like the one on my US 550F. I have a replacement label on mine and top right its marked CB550. Presume yours is indecipherable. (it's not underlined so spelled it correct first time!)
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline Woodside
Re: Chain gaurd
« Reply #8 on: May 19, 2017, 11:52:49 AM »
Cheers guys I will have a look and measure up later tonoght or tomorrow and see what it matches...
Offline Woodside
Re: Chain gaurd
« Reply #9 on: May 20, 2017, 12:34:27 PM »
Ok I think it is a 550 one although it is the same length as your 400 one kent
There are no holes other that the 2 mounting holes...
And yes sticker is damaged right where it looks like the big reveal should be
Offline Seabeowner
Re: Chain gaurd
« Reply #10 on: May 20, 2017, 03:01:55 PM »
Yes, 19" front is 550.
Offline Woodside
Re: Chain gaurd
« Reply #11 on: May 20, 2017, 04:09:12 PM »
Perfect thanks everyone
Offline Piki
Re: Chain gaurd
« Reply #12 on: May 23, 2017, 04:21:32 PM »
400 Four chain guard has a "little back plug" on it...........
